Toshiba RD-XS32 fan noise
Discussion in 'Blu-ray & DVD Players & Recorders' started by skyline32, Aug 9, 2004.
  1. skyline32
    skyline32
    Aug 9, 2004
    75
    I picked up an XS32 on Saturday morning and having played with it for a day or so I am rather disappointed with the fan noise, which is clearly audible from a few feet away. A bit like having a PC next to the TV.
    I would be interested to know if anyone has tried:
    - disconnecting the fan
    - fitting a resistor in series with the fan to slow it down
    - running with the fan disconnected and the lid off - is the disk noisy?
    - any other method of reducing the noise output
  2. Nicky
    Nicky
    Nov 5, 2003
    179
    +5
    There's a thread on this that's about 2 weeks old (an idea for the fan noise). The quick answer is fitting a resistor/thermistor works well at cutting noise but the machine generates quite a lot of heat so its not clear cut that it's sensible to cut the level of cooling.
    Nick
