Toshiba RD-XS32 Connection
Discussion in 'Cables & Switches' started by The Iceman, Jul 31, 2004.
  1. The Iceman
    The Iceman
    I am about to purchase the RD-XS32 but suddenly started getting confused re connections.
    I want to connect both my Sky digital tuner and Sony Freeview Box to the recorder to enable me to select which source to record from, and still be able to select an alternate source/channel on the TV. I have two Scart sockets on both the Digibox and Freeview but looks like only one SCART input on the recorder? Am I restricted to connecting one up via the coax? Or should I be choosing the Panny E85 instead? (My TV is a PD30 with plenty of AV connections).
    Thanks in advance for any help
