Toshiba RD-XS32 Blank Media
Discussion in 'Blu-ray & DVD Players & Recorders' started by Nathan Brazil, Nov 29, 2004.
  1. Nathan Brazil
    Nathan Brazil
    Nov 27, 2004
    196
    The beautiful Isle of Wight
    +3
    This is a thread for owners of the Toshiba RD-XS32 to post experiences and reviews of blank media. What has worked for you, and what should people avoid like the plague?
    Nunew33 said:
    I use datawrite greys 8x (no coasters), Ritek a grade printables (no coasters), bulkpaq orange 4x (few coasters no use on PC only)
    Dont use -RW used TDK 1 speed and they all failed use on PC only now
    DVD RAM Panasonic and toshiba, no problems to date.
  2. tobyjuggler
    tobyjuggler
    Nov 4, 2004
    643
    +7
    DVD-R : Infiniti 4x fine when recorded and played back in Toshiba, but no good if burnt on a PC then played back on Toshiba.
    DVD-RW : Infiniti Professional 2x (Reference Series) have been fine in all circumstances.
  3. JohnC
    JohnC
    Aug 12, 2003
    164
    Central England
    +4
    Maxell -RW.
    Work no problem and RD-XS32 recordered material play fine on other makes of DVD Players.
    John
  4. raydawson
    raydawson
    Nov 26, 2004
    232
    28
    UK
    +27
    TDK 2x version 1.1 -RWs work fine, but TDK 2-4x version 1.2 don't. They give an error message saying 'locked'.
    The manual says the Tosh works with DVD-RWs version 1.1 and above, but it seems it doesn't like version 1.2 discs.
    Cheers,
    Ray D
  5. Geoggy
    Geoggy
    Oct 23, 2002
    2,645
    in that number
    +253
    does the machine use ram discs in or out of the casette thing?
    (soz - noob)
    can some one post a link for suitable ram discs?
    ta
  6. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Lytham St Annes, where people are put out to grass
    in caddy and out
  7. Nathan Brazil
    Nathan Brazil
    Nov 27, 2004
    196
    +3
    :smashin: It would be helpful if posters also included website details of blank media sellers they find give good service. Previously, for use on PC, I've been very pleased with blank DVD-R bought from http://www.bigpockets.co.uk/
  8. liteswap
    liteswap
    Jun 21, 2004
    336
    East Sussex, UK
    As I've said in another thread on this issue just three days ago, I've burned 100 Ritek Movie Reel DVD-Rs with complete success. Get them from ebuyer.com.
  9. AVFan7667
    AVFan7667
    Nov 29, 2004
    170
    16
    Has anyone any experience with Verbatim media?
    I am ready to purchase my Toshiba RD-XS32 and want to make sure I have some media for when it arrives.
    I found Verbatim -R, -RW, and RAM for good prices but don't know if it will work well in the recorder.
    Is it the case that most 'brand names' will work or is it not that simple?
    Also, what speed discs work best?
    And finally - are there any problems using double-sided media?
  10. JohnC
    JohnC
    Aug 12, 2003
    164
    Central England
    +4
    Mitsubishi -RW 4.7 GB "Black Diamond" from Poundland (for £1) works a treat with excellent quality recordings.
    John
  11. Dark Eyes
    Dark Eyes
    Jun 4, 2004
    128
    I have been using Verbatim printable -Rs for 6 months - with no coasters or compatibility problems.
    I use TDK Scratchproof -RWs, as Computing Which? rated them best in a test that included some physical and optical abuse; again with no problems.
  12. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    I'm a new XS32 owner.
    Tried (several) Verbatim -RW (2X, version 1.1) and they do not work for me at all. A shame as I've had good luck in the past with Verbatim on my PC drive, so I bought a bunch of these. I can format the disc, record/dub to it, but when I go to finalise it, it goes through the complete finalisation process, then gives an error "Disk Management: The disk is unrecognised".
    -RW was one of the main reasons I chose the XS32 over the Panasonic, so I'd really like to get this to work! I'll try TDK or Maxell.
    Verbatim -R (4X, pastel coloured ones) work fine.
    Mark
  13. mr digital
    mr digital
    I have used Pio Data 4x DVD-R with great success so no problems there. I have also used Mirror Platinum DVD-R many times with no problem apart from the last time i used one for recording.
    It appeared to record ok but would not play afterwards.
    This might be a one off fault so i will try another to see what happens.
    As yet, i have not tried other discs apart from Panasonic RAM which seem to be bullet proof anyway.
  14. Nathan Brazil
    Nathan Brazil
    Nov 27, 2004
    196
    +3
  15. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    Nathan - thanks, I missed that one.
    Mark
  16. oldie
    oldie
    I found Verbatim -R, -RW, and RAM for good prices but don't know if it will work well in the recorder. (Quote)
    I can confirm that the Verbatim 4x DVD-RW appear as 'write protected' so cannot be used. No version no on pack but they have a SERL coating (noise reduction layer). I'm glad I only bought a 5 pack to test!
    For DVD-RAM the Maxell 3x v2.1 seem to work well.
  17. jon99
    jon99
    Nov 7, 2002
    48
    9
    I have used Verbatim DVD-R 4x (about 6), Panasonic 4x (about 5) DVD-R and Grey Labels 4x DVD-R (8 used) so far without any coasters.
    I haven't tried any DVD-RW or either of my RAM disks yet.
  18. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
  19. raydawson
    raydawson
    Nov 26, 2004
    232
    28
    UK
    +27
    My XS32 does that as well with the TDK 2x -RWs - but if I eject them and put them back in they play fine. They are also OK in another DVD player.
    I don't know why the Tosh gives the error message.
    Cheers,
    Ray D
  20. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    Wow - I didn't think to try that! I'll try that tonight. I did try and play the DVD straight away and that didn't work, but I didn't try to eject and play, nor did I try it in another player.
    I just received some TDK discs in the post, I'll try them too.
    Mark
  21. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    Ray,
    Indeed - the Verbatim -RW (2x) discs I made do play fine - on both the XS32 and my 2 other DVD players!
    So, does everyone get that error when they use -RW?
    Thanks for the tip - I never thought to ignore the error, eject the disc, and try it!
    So add Verbatim -RW 2x to the "good" list.
    Mark
  22. linkster
    linkster
    Nov 24, 2004
    711
    +15
    Where's the best place to buy these from?
  23. AVFan7667
    AVFan7667
    Nov 29, 2004
    170
    16
    Ebuyer, although their customer service is pretty damn poor, are very reasonably priced I found for DVD media.
  24. Irod
    Irod
    Ray,
    I've had the same problem with TDK 4x -RW. The DR1 says that the DVD-RAM must be unlocked.....?? (confusing when I'm using -RW)
    Does anyone know of a way round this problem or should I forget it
    Cheers.
  25. jdarushall
    jdarushall
    Anyone tried Datawrite x8 Yellow yet (Ritek dye?)
    The datawrite grey x8 work OK if they are "fujicode" dye but the last batch I got were "Prodisc F01" and will only record at 2X.
  26. TVHEAD
    TVHEAD
    Nov 29, 2004
    59
    11
    Mr DVD 4x Tesco 10 spindle £6.00 buy one get one free £6.00 = 20 disks
    copied a film played on my daughters philips
  27. geordie
    geordie
    Oct 4, 2002
    80
    11
    Enfield, Middlesex
    +3
    Refuses to work with Verbatim 4x -RW (says it is locked and will not format).
    100% success with everything else I have tried including cheap Ridata RAM (double-sided caddies), Traxdata 2x -RW, Samsung 2x -RW (£1 each), TDK -R and Datawrite Classic 8x -R.
  28. almara
    almara
    Oct 13, 2004
    52
    Recently got my Tosh and my first try with RW (Datasafe 2X) seemed to be successful - I recorded on hard drive, transferred to RW and then finalised it. Played back OK on both Tosh and PC. However, it won't let me cancel finalisation or format disc so it seems I'm left with a RW which I can't use again. Has anyone had a similar problem or knows of a solution?
    I got the RW as part of two sample packs I bought from www.blankdiscshop.co.uk. I've tried the following DVD-Rs from these packs to copy movies on PC and all have played back OK on Tosh. Don't know if there would be any difference if I'd done the recording on the Tosh.
    Ridisc Printable 4X
    Ridisc 1-2X
    Taiyo Yuden 8X full face printable
    ANV-Ritek Dye 8X
    Bulkpaq Prodisc 8X
    Ridisc 8X
    Bulkpaq Printable 8X
  29. Neville Street
    Neville Street
    Jul 11, 2004
    290
    +4
    almara - with no menu selected and with the finalised -RW in the player and "DVD" selected press "quick menu". One of the options is disk management and if you select that the unfinalise should be there. I am not with my m/c, so apologies if that doesn't work, but I am sure that is how I do it.
  30. almara
    almara
    Oct 13, 2004
    52
    Thanks Neville but this is what I've tried and get the message "operation cancelled due to error on disc". When you try to format message is "this DVD cannot be formatted".
