Toshiba RD-XS32 audio skip on DVD
Discussion in 'Blu-ray & DVD Players & Recorders' started by Greamec, Feb 17, 2005.
  1. Greamec
    Greamec
    Jan 23, 2003
    200
    19
    S.E. England
    Hi all,
    Got my Toshiba RD-XS32 today and the first thing I did was play a DVD (Gladiator) problem is that every now and then the audio skips like it can not read the disk. The disk played fine in my old player, does anyone know what is going on?
    Thanks Greame
  2. Greamec
    Greamec
    Jan 23, 2003
    200
    19
    S.E. England
    Just tried another disk and the same thing happened , played fine for a bit then the player had trouble reading the disk causing the sound to skip.
  3. El_JimBob
    El_JimBob
    Dec 4, 2004
    115
    16
    There are a few threads about this place mentioning this exact problem - most peeps have been able to get their recorders exchanged under guarantee.
  4. calibos
    calibos
    Aug 4, 2000
    957
    Ireland
    +40
    Got my RDXS32 2 weeks ago and had the same problem. My retailer exchanged no problem and the replacement works fine. I did get them to hook it up and put on a dvd to check before leaving the store though :D
  5. Greamec
    Greamec
    Jan 23, 2003
    200
    19
    S.E. England
    Thank god for that, cheers for you help. Can you tell me what you used to search to find the other threads.
    thanks
    Greame
  6. Greamec
    Greamec
    Jan 23, 2003
    200
    19
    S.E. England
  7. SDHoward
    SDHoward
    Nov 1, 2004
    250
    I think on reading that it implies you have the problem straight out the box, 'phil' not having tried any pre recorded dvd's previously.. so we should be safe....now wheres a piece of wood
  8. robkgriffiths
    robkgriffiths
    Nov 21, 2004
    46
    Same thing happened to mine. I had it exchanged 2 months after purchase through Unbeatable.co.uk.
  9. Greamec
    Greamec
    Jan 23, 2003
    200
    19
    S.E. England
    Well credit to RGB , I phoned at 10 am and at 1pm the broken player had been collected. Amazing service, new onre should be sent out monday.
    Greame
