Toshiba RD-XS30 HDD problems
K
knightman
I had left this for a few months in standby without use, and on connecting it up again the HDD does not work - On start up says it fails to authenticate and when you try to access it says there is no room left - everythin gelse works fine - saves and records to DVD drive.
Any ideas if I can do somethig myself to rectify this
and where can I find a good repairer near Kingston Surrey
thanks
joeloaded
hi,
Did you get this resolved as mine has had same problem but dvd drive not working with dvd-r or ram.Works on pre recorded but doesn't record onto disks.
