Toshiba RD-XS24
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by petehbsn, Mar 16, 2006.
  1. petehbsn
    petehbsn
    Mar 16, 2006
    Can anyone find a region hack for this dvd-hdd player ?:) :lease:
    many thanks
    Pete
  2. ferris57
    ferris57
    Jan 18, 2003
    874
    Ensure that there is no disc in the tray,
    Using the remote:
    1, Press the “0” button 5 times at approximately one second intervals.
    2, Press the “Instant replay” button.
    3, Press the following sequence of numbers very quicly (less than one second
    intervals) :
    If your player is a Region 1 machine, the sequence of numbers to press is 2,
    9, 3, 3, 4 and 9 :
    If your player is a Region 2 machine, the sequence of numbers to press is 5,
    7, 5, 3, 8 and 9 :
    If your player is a Region 3 machine, the sequence of numbers to press is 5,
    6, 7, 3, 2 and 9 :
    If your player is a Region 4 machine, the sequence of numbers to press is 5,
    6, 8, 8, 4 and 9 :
    If your player is a Region 5 machine, the sequence of numbers to press is 5,
    3, 8, 1, 4 and 9 :
    If your player is a Region 6 machine, the sequence of numbers to press is 2,
    4, 4, 6, 2 and 9 :
    4, Open and then close the tray.
  3. mburke33
    mburke33
    Jan 11, 2006
    7
    3
    Maybe I am doing something wrong but the hack didn't work for me.
    I have a region 2 machine and was trying to watch a region 4 dvd but with no joy.
    Can you confirm if when entering the numbers on the remote that you switched from operational to number on the side of the remote ??
    Did you enter the region 2 code to unlock the machine or do you have to enter the specfic region code for the type of disk you are trying to watch.
    Any assistance would be appreciated.
  4. whatsup
    whatsup
    Tried the same solution on my Toshiba RD-XS24 this evening, with no joy.
    Anyone else have any suggestions?
  5. xxxx
    xxxx
    Aug 27, 2005
    776
    28
    +23
    AFAIK this is a fake hack and there is no remote hack that works.
