Toshiba PW8DB info required
Discussion in 'General TV Discussions Forum' started by eros, Feb 12, 2001.
  1. eros
    eros
    Does anyone know of a website that has info about upgrades and setup tips for the above TV?
    Don't say toshiba!
    Cheers.
  2. Godfather
    Godfather
    Feb 12, 2001
    2,345
    63
    Edinburgh
    +225
    If you want I can tell you how to get into the service menu where you can adjust every possible aspect of the picture. You must know what you're doing though otherwise there's every chance that it can get screwed up!
    Which PW8DB is it - 40" or 56"?
