Toshiba Projector help
Discussion in 'Projectors, Screens & Video Processors' started by mkonops, Sep 23, 2005.
  1. mkonops
    mkonops
    I have owned a toshiba TLP-510 for about 5 years using it regularly without a single problem until recently. Normally when the unit is plugged in an LED will illuminate at all times. This light no longer comes on when it is plugged in and the unit will not power up. I purchased a second one with a bad bulb for parts off ebay and it powered up 2-3 times but then failed with the same problem. I would like some help diagnosing this issue before picking up a third or switching models. The power supplies in both sound like they are working (normal high pitched noise on plug in) but neither will boot or even turn the fans on. Has anyone else heard of such a problem? Please advise!
    Thanks, Mike
