Toshiba problems.. who ya gonna call...?
Discussion in 'General TV Discussions Forum' started by Bimbeemer, Feb 20, 2002.
  1. Bimbeemer
    Bimbeemer
    Feb 15, 2002
    310
    Hampshire
    +64
    Can anyone recommed any good Tosh fixers..? I'm getting sick and tired of the constant "greenyness" of my screen when watching anything using the scart....I finally hooked up my dvd to another tv yesterday and Planet of the apes actually looked good...the dark areas were dark and not bloody green...!
    Thanks for your help
  2. Doubledoom
    Doubledoom
    You could have a quick look in the service menu and see if adjusting the GCUT setting improves the picture.
  3. Bimbeemer
    Bimbeemer
    Feb 15, 2002
    310
    Hampshire
    +64
    How do I access the service menu..?
    Its a 2987DB...
  4. Doubledoom
    Doubledoom
    Same way as the rest of the Toshiba models.
    Press mute on the remote.
    Press and hold down mute on the remote.
    Press menu on the front of the tv.
    The first setting should appear on the tv.
    Use channel up/down to select the different settings (until you get to GCUT) and volume up/down to change the value.
    Remember to make note of the original setting before making any changes. There has been a lot of discussion about the Toshiba service menus on these forums and on the home-cinema newsgroup. You may want to check the archives and google to learn a little more before jumping in.
