bluefoxtim
I can't find the manual to my SD330e Toshiba dvd player so I can't answer this myself.
It has component inputs available, so does this mean it will automatically upscale / use progressive scan?
I am currently using Scart through my 2nd socket (which is not full scart - makes writing fuzzy - without RGB is it?) on my LG tv.
Even if the component cable doesn't mean upscale / progressive, is it worth getting to improve the picture considering I am not using a full scart input?
