Toshiba Plasma: Horizontal ghosting/streaking
Discussion in 'Plasma TVs' started by Jon Weaver, Mar 14, 2003.
  1. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,051
    Born in Bristol but now in Newport, (for my sins)
    +664
    I have a Toshiba 42WP27 and have noticed that some foreground colours on certain background colours (say white on blue) cause feint horizontal streaks across the screen.
    My DVD player and Sky+ box are connected to the Plasma by a JS RGB-VGA conveter, but this isn't causing the problem as I can see the phenominon via Composite Video too.
    I have a couple of photos which show the problem, but they arn't as clear as I hoped.
    Can anyone else with Toshiba or Panasonic confirm whether they see the same thing, or should I log it as a fault?
      Size:
      25.7 KB
      502
  2. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,051
    +664
    And another:
      Size:
      10.1 KB
      450
  3. thxultra
    thxultra
    Feb 22, 2003
    380
    glasgow
    +4
    i have a panny 5 and it is the same just something that happens.only really see it on the screen shot you posted dont see anything when watching films though and this is with pal/ntsc prog so i wouldnt worry
  4. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,051
    +664
    Phew.. Thanks for that.. It doesn't really bother me that much, I just wanted to be sure that it wasn't a fault.
    I VERY rarely see it in normal operation, but sometimes something moves up/down the screen on the you see a feint 'shadow/streak' move with it.
    But as you say, its just one of those things.
  5. Nick23
    Nick23
    Feb 25, 2002
    121
    16
    Same thing happening to me on my 37" panny. Its strange though. I'm sure it wasn't always like that, but I've only noticed it recently. Plasma is 9 weeks old.
  6. ncpl
    ncpl
    Jan 21, 2003
    348
    Surrey
    There's a setting on my Fuji called "clamp". I forget what it does exactly, but, when I first noticed a banding on some Sky channels, setting this to -2 totally cured it. I think it's a frequency lock type setting. Auto should have been OK, but, -2 is best.
    Maybe your Panny's have a similar setting. It certainly wasn't obvious to me.
    Rgds
    Nick
  7. thxultra
    thxultra
    Feb 22, 2003
    380
    glasgow
    +4
    anyone know if panny 5 has this a "clamp" feature,if so how do you get to it think it will prob be in the service menu and you dont want to mess with that to much
  8. nathan_silly
    nathan_silly
    Looks like identical problem with right shift ghosting on Sony direct view CRT's. Weird! Shouldn't effect Plasma.
  9. ncpl
    ncpl
    Jan 21, 2003
    348
    Surrey
    Having looked at the other post with a similar problem, I think is is not quite the same as the clamp thing on the Fuji.
    Have you tried plugging in the same pictures direct to the screen rather than the tuner box ? Is that possible ?
    Until yesterday's cable change, I did have a slight ghost image on component feed, but, this was simply cable interference. Better shielded cables cured the problem. I mention this as it was a ghosting to the right of the main image....far more visible in the dark/light boundaries. How are your cables situated ?
    Just ideas...
    Rgds
    Nick
