Toshiba pj
Discussion in 'Projectors, Screens & Video Processors' started by Parmenion, Feb 6, 2002.
  1. Parmenion
    Parmenion
    Feb 6, 2002
    1,304
    Out there
    +74
    I know its "old hat" by now but does anyone have any experience or views on the Toshiba MT 1 projector.
    I have just seen a demonstration of the MT 1 and then the MT 3, to be honest, the older projector (and cheaper!) looked at least as good. I'm tempted to say beter but I'm not looking to start a fight !
    Regards
    Parmenion
  2. Technophobe
    Technophobe
    Dec 21, 2001
    129
    16
    South Coast
    Hi Parmenion,
    Just upgraded from the MT1 after owning it for just over a year.
    I think your correct in that the MT1 is as good as the MT3 and probably not worth the extra expense.
    For a cheap PJ the MT1 puts up a good fight against even some of the newer arrivals I've seen in that price range.
    If it's your first PJ you’re probably going to get the bug anyway and will want to upgrade in a year or so. This model is unlikely to de-value too much compared with the more expensive kit.
    Send me a private mail if I can help in any way.
    Technophobe
  3. Comer
    Comer
    Sep 21, 2001
    1,390
    Ireland
    +86
    I have posted extensively on my experiences with the MT3 which is really the same as the MT1 in terms of performance.
    I have used it with a couple of DVD palyers, and the iScan Pro and a Home Cinema PC. Do a search with "MT3" and my usernames "cg999" and "Comer"
    Not all I have to say is good, but it's not all bad either
    Conor
