Toshiba Picture Frame 2
Discussion in 'General TV Discussions Forum' started by Aletank, Mar 22, 2003.
  1. Aletank
    Aletank
    I have the April edition of What Video, It says in the May edition -
    ON TEST
    Exclusive reviews of Toshiba's secret Picture Frame 2 flagship TV.
    Has anybody heard about the Picture Frame 2 ? Any info or details
  2. normski
    normski
    hi
    i noticed this as well i have asked a few retailers and they no nothing or are keeping quite maybe there are lots of the pic 1 still about anyway i called tosh brochure line and they have no info but they did say it was being launched on the 6th of april at a trade show so i guess we will have to wait until the may edition of w tv and video lets hope they have sorted out the pic problems
  3. lemming
    lemming
    Mar 4, 2003
    350
    19
    Garden of England (apparently!)
    What pic probs?? as I was thinking of getting one.
  4. Oblivion
    Oblivion
    Feb 23, 2002
    524
    Milton Keynes
    Could they be taking about a Plasma??
    Paul
  5. normski
    normski
    well the original pic frame 1 was a nice looking set but was plagued by light sides on the tube so colours at the edges looked was out ant you cvould only get a good blacks in the middle of the tube check out the 36zp18 threads you will find all the info there
  6. lynx
    lynx
    Jan 20, 2002
    4,634
    It always rains.
    +302
    Use the search facility.
  7. topmba
    topmba
    Feb 13, 2003
    249
    Bedfordshire
    +4
    Oblivion
    Branding a plasma PictureFrame would be like talking about a new four wheeled Ford Focus. It goes without saying, plasmas are expected to look like that.
    The PictureFrame concept is aspirational has it pretends to look like a plasma head on.
  8. Oblivion
    Oblivion
    Feb 23, 2002
    524
    Milton Keynes
    Yeh I know the Idea
    Just can't see the point of remaketing it - Its gona take alot to beat the new Stratas for PQ
    PAL PS??? Hummmm theres a thought
    Paul
  9. kwangomango
    kwangomango
    Jan 9, 2003
    856
    Kent
    +38
    Had a quick butchers at the new issue in Cannon Street Station - 'kin train was cancelled!
    Picture Frame 2 got a drooling review. My first thoughts were that it looked quite tasty - black gloss tv frame, silver open stand,glass shelves and silver speakers(along bottom edge of tv and external). It could verge on tacky when seen in the flesh though. Definitely not as subtle as Picture Frame 1.
    Some other bits i can remember:-
    Pal prog was not mentioned.
    Not DPL 2
    Latest iteration of the Active Scan technology (Active Vision) - 32MB buffer.
    No 'Pixel Plus' type technology.
    Sound is better than some AllInOne systems the reviewer has recently seen.
    Still Only 1 RGB scart!
    Some geometry problems were noted - no change there then!
    RRP £1800
  10. topmba
    topmba
    Feb 13, 2003
    249
    Bedfordshire
    +4
    Progscan recomended for NTSC DVD.
    Does it mean no PAL progscan? The article does not specify.
  11. redlester
    redlester
    Jan 11, 2002
    104
    I bought a 32ZP18P 16 months ago and it is great. If I were ultra critical my only complaint is that when manually switching to "wide" mode to watch, say, a widescreen video i.e. something that is not anamorphic, then later going back to TV viewing, this seems to upset the automatic switching - widescreen TV channels wont kick-into widescreen automatically. The only way I've found to cure it is to switch off the TV and Sky box and then switch back on TV first, then Sky, set to BBC1 or another widescreen channel. That corrects it.
    Picture and sound quality-wise, it's near enough perfect as far as I'm concerned.
  12. jase the space
    jase the space
    Aug 6, 2002
    142
    Manual and info now available on Tosh's site. Contrary to the review in What Video, it appears the ZP38s have 2x RGB enabled SCARTs:
    EXT1: RGB/Composite In
    EXT2: RGB/Composite In
    EXT3: S-Video/Composite In/Out
    EXT4: Component In
    EXT5: S-Video/Composite In
    Note: EXT2 now fixed In (not In/Out but EXT3 is now In/Out) and no longer carries S-Video. Front S-Video/Composite connectors are now a separate EXT5 instead of sharing EXT3.
    Also added an extra Audio Out phono pair (Surround Variable).
    ZP38 is a couple of mm bigger in each dimension but a few kg lighter than ZP18. Manual briefly mentions NTSC progressive in but nothing about PAL PS in so I guess it isn't there.
    Colour temperature setting has been added. Picture tilt is again only present for 36" model.
  13. gmt steve
    gmt steve
    Aug 19, 2002
    648
    Manchester
    +6
    The new issue of What Hi-Fi claims it's PAL proggressive capable, they'll have a full review next month. They are wetting themselves over it.
  14. zantarous
    zantarous
    Dec 11, 2002
    2,022
    113
    +590
    Aaaaggghhh I phoned Tosh last week before buying a zd26 and asked if any of their TV's had a 2 RGB sockets. I was transfered between several departments and then assured that none of their TV's had this feture.
  15. kwangomango
    kwangomango
    Jan 9, 2003
    856
    Kent
    +38
    Booooooooo!!! No Pal prog unfortunately. Just got my reply from Tosh:
    Thank you for your recent enquiry. Please find the information that you
    requested as follows:
    The Picture Frame 2 TVs have the Progressive Scan Mode but only for NTSC
    pictures.
    The only Toshiba TVs which will accept a PAL progressive scan picture
    signal is the plasma screens. This is because they work more like a
    computer monitor than a TV and their normal mode of operation is
    progressive scan.
  16. Deron
    Deron
    Sep 11, 2002
    365
    +12
  17. topmba
    topmba
    Feb 13, 2003
    249
    Bedfordshire
    +4
    The pdf files in Toshibas website are basically the one page ad and the two page article from "What Video - May Edition"
    They corrected the review from print to aknowledge the 2 RGB scarts.
    What is the use of surround out R+L (variable) and R+L fixed line-out RCA sockets? Does this enhance 5.1?
  18. Goose74
    Goose74
    Sep 24, 2002
    807
    Romsey
    +12
    man I can't believe that after the strata zd36p that Toshiba have not implimented pal prog on this new set - especially since it is now legal.
    Gutted
  19. nickyvicar
    nickyvicar
    Sep 13, 2002
    282
    Hereford
    +9
  20. TopMeTom
    TopMeTom
    Sep 8, 2002
    8,228
    +261
    Best price i've founf for the 18Q=£1299.92.
    Would anyone recommend this set or wait for the new one?
  21. TopMeTom
    TopMeTom
    Sep 8, 2002
    8,228
    +261
    hmmm might wait for the new one,seems to be packaged with dvd,vcr+speaker stands
  22. topmba
    topmba
    Feb 13, 2003
    249
    Bedfordshire
    +4
    Only for a short period and with a long wait I suspect.
    Has anyone SEEN one?
  23. kerraig
    kerraig
    are these actually in shops now then? With the exception of Pal prog scan this telly has everything I want.
  24. TopMeTom
    TopMeTom
    Sep 8, 2002
    8,228
    +261
    waiting to find out,it is on some online sites!
  25. Spunky
    Spunky
    Jan 8, 2002
    113
    19
    Norwich/Liverpool
    I've been told that curry's will be getting them in stock in a couple of weeks.
    Spunky
  26. Aletank
    Aletank
    I was asking in Comet at the weekend about it, It's nt actually in stock in the stores but is listed on there computers and priced at £2000.
    The guy said they'll probably wait untill the Originals are sold before putting them out on the floor
  27. jase the space
    jase the space
    Aug 6, 2002
    142
    JL will be getting the 36" at the end of the month (no details on 32" yet though) and they will retail for £1999.
  28. kerraig
    kerraig
    Looks like i'll be going on a pricematching hunt then.
  29. topmba
    topmba
    Feb 13, 2003
    249
    Bedfordshire
    +4
    Kerraig, rather than take the plunge and get the vcr and dvdplayer thrown in?
    Do JL price match with such largesse?
  30. kerraig
    kerraig
    I've just learned a harsh lesson about taking the plunge. Bought a Panny 36" from an internet retailer. Wasn't happy with the thing and had to go to court to get my money back. I'm gonna be particularly careful this time.
    JL won't price match against an online retailer, but some clever hunting/haggling can save you a fortune.
