Toshiba or poineer
Discussion in 'Blu-ray & DVD Players & Recorders' started by kevb, Jun 27, 2002.
  1. kevb
    kevb
    May 16, 2002
    1,099
    41
    About
    +3
    What do you think wins in sound and picture quality stakes.
    Budget range: Toshiba 220e or pioneer 444.
    Mid range: Toshiba 510e or pioneer 636.
  2. bob007
    bob007
    I have the pioneer 636 so i have to say that.
    It's multiregion, never had any problems with it, plays everthing i chuck at it.
    Bob
  3. Pete Callan
    Pete Callan
    Apr 23, 2002
    104
    16
    London
    These are the choices I was faced with recently. I ended up getting the 510 from dvdplayers.co.uk and although I have no doubt the 510 is an excellent DVD, in hindsight perhaps I should have bought the 220.
    The 220 is only a few weeks old, it has more picture features and it was about £100 cheaper. The thing that stopped me getting the 220 was that I'd heard it was quite noisy when playing discs, which is something I can't stand. The 510 is dead silent. Then again, I've also heard the 220 is silent, so maybe that was just a stupid rumour about it being noisy. Anyway, the Pioneers are a little lacking in features although they are good DVDs all the same.
