toshiba mt8
Discussion in 'Projectors, Screens & Video Processors' started by meva, Aug 7, 2002.
  1. meva
    meva
    Feb 20, 2001
    348
    cornwall,uk
    +13
  2. ian_guinan
    ian_guinan
    Apr 14, 2001
    1,164
    38
    Australia
    +18
    Very exciting..should liven up competition.
    For those non-french speakers amongst us here is a rough Babelfish translation of the specs.
    Very pleased about Carl Zeiss optics, not so sure about 35dB of noise. Very much looking forward to seeing one!
    Regards,
    Ian Guinan
    1000 Lumens ANSI, contrast 1000:1
    New panel DMD HD2 by TI
    Native resolution 1280 X 720 pixels
    True TV HD
    New Faroudja DCDi+ FLI2300
    Entirely sealed light unit Identical to SIM2 and Marantz
    Lens and optical glass Carl Zeiss
    Logo on the ring of development
    New chromatic wheel RGB Number of revolutions 5x 9000 tours/min
    Frequency 300 Hz automatic Calibration
    Circuit electric of anti-flicker lamp
    Extra-broad video compatibility
    NTSC: M, 4.43
    STAKE: B, G, H, I, M, N
    SECAM: M
    EDTV: 480p, 576p
    HDTV: 720p, 103ï, 1080i(50/60 Hz), 1080p (60 & 24 Hz)
    Frame leak-preventer of light
    Double mode of luminosity
    Normal & # 8211; Logist lifespan of lamp, low noise level of ventilation
    High luminosity
    12 languages on L & #8217;OSD
    English, Spaniard, French, German, Japanese, Korean, Portuguais, Italian, Norwegian, Russian, Simple Chinese, Traditional Chinese
    Temperature of color preset with 6500K white not
    3 possible presettings
    6500K - by defect
    8200K
    9300K
    1 adjustment memorable user
    2 catches 12 volt + 1 catch repeater IR
    Compatible entry DVI HDCP
    Auto-ignition
    Controlled in the telegraphic centralized installations
    Low noise level, fluid circulation of flows D & to #8217;air in L & #8217;appareil
    H-sync frequencies
    21-91kHz
    V-sync frequencies
    50-85 Hz
    Dowry clock
    135 MHz
    16,7 million colors
    Digital correction of parallax
    +/- 20°
    Optics
    Zoom (x1,4) and developed handbooks
    Logo Carl Zeiss
    Pt-to be also Vario-Sonnar® logo
    Power supply
    consumption 350W
    100V - 240V 50/60 Hz
    35 dB in normal mode
    New DMD TI HD2 LVDS 12°
    new ASIC DDP1010
    coil chromatic RGB 6 segments 5x
    Report/ratio of projection (distance/bases)
    1,49-2,08: 1
    Outdistance projection
    1.5 to 10 m
    Report/ratio D & #8217;image
    16:9 native
    Modes of projection
    Frontal, back, ceiling
    Not D & #8217;audio integrated
    & #8216;beep & # 8217; with the powering
    Lamp
    250W UHP
    1500 hours
    Dimensions & weight
    330 X 89 X 229 mm (L X. X P)
    4 kg
    Certifications
    Class B, UL, Csa, EC, TUV, C Tick, NAME, MIC, GOST, IRAM, CCC, S-jqa, FCC B, EN55022, Ices-003
    DCDi+ (Wise chip FLI2300):
    All functions of the DCDI
    Scaler: redimensioning & #8221;intelligent & # 8221; signal D & #8217;origine with the resolution of the matrix of projection
    Improvement and compensation brightness/chrominance
    Conversion of the frequency of screens (on sources 1080p/24 Hz)
    DCDi+ is L & #817;integration on chip FLI2300 of the functions of FLI2200 + FLI2220
    Price ~ 8990 euros (under reserves)
    Availability: October 2002
    _________________
  3. jrwood
    jrwood
    Looks good, it only mentions the noise level in normal mode which is a loud 35db. I wonder what other modes it does ?
  4. ian_guinan
    ian_guinan
    Apr 14, 2001
    1,164
    38
    Australia
    +18
    Have heard 'mutterings' of a european price for the Infocus version of this to be around 7500 euros without local VAT, so could translate to a UK price of under £6K. Toshiba could be different though.
    Take this with a pinch of salt of course and bear in mind that in the past Infocus have been pretty good as regards the discounts you can find if you shop around. I think this 'Screenplay' projector will not be available in all the usual Infocus outlets though.
    Either way a bright, high contrast HD2 projector with Carl Zeiss optics at this sort of price is most welcome, and might force Sim2 to be keener with their pricing.
    Regards
    Ian Guinan
  5. ian_guinan
    ian_guinan
    Apr 14, 2001
    1,164
    38
    Australia
    +18
  6. ian_guinan
    ian_guinan
    Apr 14, 2001
    1,164
    38
    Australia
    +18
  7. gwbailey
    gwbailey
    Well the first reports coming in from CEDIA are looking very good about the MT8/Screenplay7200 over at AVS.
    Maybe we have a winner here guys?
    Also, I've yet to hear bad rainbow reports!
