Toshiba MT8 Picture Size Problem!
Discussion in 'Projectors, Screens & Video Processors' started by Mark Antony, Apr 2, 2003.
  1. Mark Antony
    Mark Antony
    Mar 19, 2003
    289
    28
    Herts
    +38
    I did a search, I don't think this has been solved before...
    I have a Toshiba MT8 DLP projector and miscalculated the screen size, as a result even on minimum zoom the projected image is slightly too big for the screen - it will be a real pain to get a different mounting bracket, does anyone know if hidden in the service menu is a way to shrink the vertical and horizontal image size - like on most tv's and if so, how?!
    Your help is much appreciated
    Regards
    MA
    NB am expecting the DVI-USB cable shortly to be able to upload the infocus 2.9 software onto this device and will also be getting it isf calibrated by Gordon of convergent av, will keep anyone interested posted...
  2. ian_guinan
    ian_guinan
    Apr 14, 2001
    1,164
    38
    Australia
    +18
    Yikes! That's bad news. I too have an MT8 and regretfully no lifesaving solution..however you did it if it was possible would mean using less of the widescreen panel you've bought and less resolution.
    How much is it out?
    Would turning overscan 'on' make enough of a difference.
    I'd be intrigued as to how you get on with your calibration as colour wise the MT8 seemed very good out of the box. I've so far done very little tweaking.
    Regards,
    Ian Guinan
  3. ian_guinan
    ian_guinan
    Apr 14, 2001
    1,164
    38
    Australia
    +18
    p.s. it might just concern you to know that Toshiba UK are claiming that the Infocus 2.9 firmware is incompatible with their MT8 projector and may cause operational problems...
    I think they are talking rubbish, but without a way to revert to Toshiba 2.5 I'd be nervous if anything happened to my projector if I upgraded. Talk on the AVS Forum is moving towards cajoling Toshiba USA to release a newer firmware...we'd be on safer ground then.
    Regards,
    Ian Guinan
  4. Mark Antony
    Mark Antony
    Mar 19, 2003
    289
    28
    Herts
    +38
    It's out about 6-7"... :-( bascally my only solution is to mount it on the ceiling which I don't really wanna do...
    Will let you know how the calibration goes, but on my screen at the mo blacks look grey - very light, too light so hopefullt this should help to an extent
    Will let u knowe how Gordon gets on..
    Regards
    M
