Toshiba MT3 lamp replacement
Discussion in 'Projectors, Screens & Video Processors' started by alan8477, Jan 7, 2004.
  1. alan8477
    alan8477
    Dec 17, 2001
    593
    Pershore
    +11
    I have a Toshiba MT3, just put a new lamp in and experienced two problems:
    1 Despite following the instructions that came with the lamp I could not reset the clock/no. of hours. Instructions say hold down on/off, menu, input at the same time whilst plugging into the socket! That takes some doing! Anyway didn't work.
    2 After a few minutes use the lamp went off! Two RED L.E.D.s came on and the projector powered down. Did this a couple of times before it refused to illuminate at all. Great anxiety as the replacement lamps are £340!
    I put the old lamp back in and everything is OK again. The problem with buying a replacement lamp is that with only a 90 day warranty you are obliged to use it sooner rather than later.
    Anyone with a Tosh carried out a lamp replacement?
  2. davrob
    davrob
    Alan,
    What Tosh dont tell you is that there is another key press sequence for reseting the lamp timer.......try holding down the menu key and on/off key and then plugging in the mains. The projector will confirm the reset by lighting up all 3 leds orange.
    I repair many projectors a week including Tosh TLP 470 etc so if you require any more help.....
    Dave :p
  3. alan8477
    alan8477
    Dec 17, 2001
    593
    Pershore
    +11
    Thanks Dave. Would the failure to reset have caused the lamp out problem?
