Toshiba MT3 - just arrrived!
Discussion in 'Projectors, Screens & Video Processors' started by buns, Jul 21, 2001.
  1. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    arrrrgh a ghost
  2. Guest
    Hi Phil,
    Great to hear your happy with your MT3. I bought the MT1 about a year ago and have had nothing but praise for it.
    I use a component connection from my dvd player, and am very pleased with the quality.
    Are you using a screen?
    :D
  3. Phil White
    Phil White
    Currently using a Jessops 6' tripod screen - although I want to get/make a similar sized pull down jobee! Does any one think that paying an arm and a leg for a screen produces particularly better results?
  4. Guest
    All I can say is that I used to project onto a painted wall. Then I bought a 7' electric screen from owl and I was amazed at the difference. Much better colours and a brighter picture.
    Not sure about the difference between your screen and a purpose video screen. Although the shape would be better for you i.e. 4:3
    not square.
  5. Guest
    Phil
    Glad that your enjoying your unit . Hope to have mine back sometime next week .
    Darren
  6. Phil White
    Phil White
    Having owned one of the early Sharp LCD projectors (circa 1994) then moved on to a Davis DL450 I took the plunge and ordered an MT3. HiWay Hifi in Edgware Rd offered me a great price £2349 and delivered within 24 hrs. Impressed? I should coco! V.Bright, natural colours and excellent definition. I'm currently running S. Video from a Pan. 360 DVD. Is it worth getting an RGB lead given that it'll need to be 10 metres long?
    Finally, if your dithering about which unit to get - go for it and order an MT3!!!
