Toshiba MT200 RGB connection
Discussion in 'Projectors, Screens & Video Processors' started by Lyricman, Apr 6, 2005.
  1. Lyricman
    Lyricman
    May 19, 2004
    241
    UK
    +21
    I am thinking of buying the Toshiba MT200 and was wondering about how to connect a sky box to it. Can I connect the Sky Scart in RGB mode to the RGB DSub input on the Toshiba or do I need a scart to component cable to connect to the component inputs on the Tosh.
    Is there a maximum length for this type of connection and will the picture deteriorate the longer the cable.
    Any help would be appreciated.
  2. PJTX100
    PJTX100
    Dec 21, 2004
    8,134
    +564
    I have 15m component and DVI with no deterioration I can detect.
    Unsure what a DSub is, a Scart to Component is a pretty standard connector - it does the presume the tosh can be adjusted to take RGB into the component as well as the "true" component though...PJ
  3. Lyricman
    Lyricman
    May 19, 2004
    241
    UK
    +21
    thanks for your help.
    I was looking for Scart RGB to either VGA or Component.
  4. ZippyCat
    ZippyCat
    Aug 9, 2004
    573
    28
    +22
  5. MikeK
    MikeK
    Oct 9, 2004
    2,231
    83
    +316
    A Syncblaster cable or box from Keene is another option (a bit cheaper too).
    But heed the warnings on the site posted by Zippycat - for these products to work with a Sky box, the PJ's VGA port must accept an interlaced input with HV sync signals of 15.625kHz for Hsync, and 50Hz for Vsync (at the same time) - if it won't then this idea is a non-starter!
    There are always alternatives, but these tend to walk hand in hand with progressively higher prices - it's up to each to then decide whether the price is worth paying, considering the typical quality of the Sky source signal.
  6. ZippyCat
    ZippyCat
    Aug 9, 2004
    573
    28
    +22
    The MT200 can accept signals in the range:
    H 15 - 93kHz
    V 50 – 85Hz
    Hence the QED Q–Sync in the above link will work.
  7. Lyricman
    Lyricman
    May 19, 2004
    241
    UK
    +21
    Thanks for the replies. Is the best picture through the VGA or through the component with progressive scan.
