Toshiba MT200 cuts out. help required.
cyberheater
Right. I've got it mounted on a high shelf on the back wall. The shelf is about 8 inches from the ceiling. The projector is upside down and I have the lamp on low power and the fan on standard.
When watching movies. Sometimes the projector light just shuts down and the pj enters into a cooling cycle. I don't get any warnings etc... and it's getting annoying.
Has anyone else experienced this. Do I have a duff unit.
cyberheater
andrewfee said:
I assume you've got it raised up off the shelf a bit?
I have but maybe not enough. Time to go to the garage and sort me out some longer stand offs.
windie
I had this happen once, but I put it down to a stupid person (me) hitting the wrong button on the wonderful remote that comes with the unit.
Mine is on a shelf just above head height when you are seated the right way up so no chance of any buttons being pressed.
Other than this and I am still not completely sure if I did press a button everything has been fine.
cyberheater
Okay. It happened again last night.
The led's are:-
Lamp, temp, fan on green.
On is red lite which means 'power went out during normal use - internal problem with the projector'.
Looks like I'll have to request a RMA.
