Toshiba MT100 and vga adaptor
Discussion in 'Projectors, Screens & Video Processors' started by tonyburns, Jul 23, 2005.
  1. tonyburns
    tonyburns
    Jul 20, 2005
    11
    3
    hi
    my pal just bought 1 of these the pictures pretty good
    i know u can get progressive scan with a pc with the projector
    he dosnt want to use his pc with it
    can he use a vga adaptor and connect his sony progressive scan dvd player using the componet connection on the player to get progressive scan with the vga connection at the back of projector
    if he can where can he buy a cheap vga adaptor that will accept a component cable
    thanks
  2. Squat
    Squat
    I seem to remember my mates MT100 had a component adapter that plugged into the modified S-Vid connector. This should accept a progressive signal.
    :rolleyes:
  3. Marty Williams
    Marty Williams
    Aug 5, 2005
    54
    I think I've got a spare one somewhere. I ordered a few from the states when Infocus decided to start charging £50 for one and then wound up not keeping the X1.
    Drop us your details and I'll see if I can dig it up.
    The Tosh MT100's the same as the X1, isn't it?
  4. Squat
    Squat
    The only difference is the chassis colouring, 50 bucks sounds like a good business to be in :smashin:
  5. Marty Williams
    Marty Williams
    Aug 5, 2005
    54
    Yeah. Infocus. Bastards.
    Orignally the component converter was about £15. As the X1 started proving popular for home theater, they hiked the price to £53 (!!!)
    So I ordered 3 or 4 of them for me and me mates from the states at $15 per piece.
    And then I decided to not keep the X1 after all.
  6. 682194
    682194
    May 1, 2006
    138
    I have a posting that I believe refers to this thread?
    Is this the cable that I need to allow me to connect the MT100 to a progressive scan dvd player (JVC-THS55) ??
    Please can anyone help me by telling me where I can get this cable???
