Toshiba LCD Advice needed
Discussion in 'LCD & LED LCD TVs' started by finn1581, Apr 1, 2005.
  1. finn1581
    finn1581
    I recently brought a Toshiba 27WL46 LCD TV.
    Couple of questions (ok 3)
    1.Although it hasn't got a HDMI conector can it display HD images?, it has 720x1280 resolution.
    2.It has a input marked DVI-D but since searching the net I now think this is just a DVI port and not DVI-D. I want to use my laptop to coneect up to the TV to stream movies, DVD's etc. My laptop has a DVI-D conector. Will it work using a DVI to DVI conector. I'm currently using an S-video cable but would like to switch to a DVI if it would work. Would it improve the picture over svideo or vga?
    3. Does anyone know where I can get a DVI Xbox cable??
    Many Thanks
    Finn.
