Toshiba HDMI DVD Player DTS Issue
Discussion in 'Blu-ray & DVD Players & Recorders' started by bshadfan, Jun 5, 2005.
  1. bshadfan
    bshadfan
    So I just got a 46" Samsung DLP with an LG 1200w Home Theater System (comes with a dvd recorder/player). I also got a Toshiba HDMI DVD player..
    So I have the LG Receiver connected with regular red/yellow/white cables to the TV's video/audio out.. (haven't gotten component cables for this yet)
    Then I have my Toshiba DVD player connected to my TV with HDMI..
    This works nicely but the catch is I can't play DTS through my Toshiba DVD player. If I play a dvd with the LG dvd player DTS works fine (but the picture sucks). Dolby Digital works perfectly with the Toshiba but for some reason the DTS doesn't. Does anyone have any idea why its doing this?
    Would I have to connect the Toshiba to the LG dvd player with coaxial or optical whatever? Or maybe using component cables with the LG to the tv would do it?
    any help is appreciated, thanks
    basil
  2. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,122
    London
    +393
    Try set your audio output in the Toshiba to Bitstream and not PCM.
  3. azz
    azz
    Feb 22, 2003
    644
    28
    Nottingham
    +22
    bshadfan
    Can you let me know if the tosh hdmi is better than the tosh component-P
    I was thinking of buying this player (350e).
    Where did you get it from
    Azz
  4. boab_is
    boab_is
    you need to connect the Toshiba DVD to the LG home cinema unit, using either a co-axial or optical digital lead. if you use anything else, all you will get is stereo or analogue surround.
  5. Deano70
    Deano70
    Aug 11, 2004
    357
    bshadfan where did you get your HDMI Tosh player from ?, is it the SD350E how do you rate it im very interested in getting this unit.
