martian1
Hi all need a little help i finally replaced my home cinema amp so i can listen to the hd audio formats the reciever i have is a SONY STRDA2400ES it works fine with my blu-ray player but i can only seem to get linear LPCM via the Tosh. I know this is a old format now and the manual does state it isnt compatible with dts hd master so i assume you would get linear LPCM but i though it would output treuhd etc. In the Tosh menue you only get 2 options for hdmi audio..AUTO and PCM i have left it on auto is that correct ?
Any help appreciated
