Toshiba HD DVD and its PSU -- can it be swapped
Discussion in 'Blu-ray & DVD Players & Recorders' started by StooMonster, Aug 28, 2006.
  1. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    Having watched a video this afternoon of someone taking a Tosh HD A1 to bits, and how it's very similar to a PC, the thought struck me ... can you use a PC ATX PSU in the case? If this were possible, it would easier (and safer) to install a new PSU than use a mains transformer.
    StooMonster
  2. jsgreen89
    jsgreen89
    Jul 23, 2004
    706
    +17
    Interesting idea...
    Would seem like a simple thing to do.
    Is it a standard mini-ATX mobo?
  3. jsgreen89
    jsgreen89
    Jul 23, 2004
    706
    +17
    Hmm just looked at that video of the inside of the player:
    http://hdvforever.com/blog/HDDVD.wmv
    And it doesn't like a standard PSU on the inside at all. Might be possible if you knew what you were doing... but I wouldn't risk it :eek:
  4. Avi
    Avi
    Dec 30, 2004
    13,963
    +2,064
    If the Euro model shares a similar chassis and main comps it way be worth ordering a Euro PSU as a spare part give there not fare away.
    AVI
  5. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Stoo, you really should get out more.... sorry!
  6. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    LOL, well it was on a DVD someone gave me ... but I did have it running at 2x speed. ;) And I am always up for modding a bit of hardware. :)
    StooMonster
  7. gilford
    gilford
    Feb 12, 2005
    7,599
    Welsh riviera........
    +1,012
    I'm using one of the 100w step downs a lot of members bought off flea bay, I have had it on constantly now for 2 weeks and although it gets a little "warm" it seems fine. What made me worry was it said on the box "Not for continuous use"? It also states it has an overheat cut out so surely it is safe to just leave on all the time?
    What do you think?
  8. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    I guess anything which says 'not for continuous use' would be best turned off overnight, or if you are away. Pretty sure it won't cause a fire, but the overheat cutout may not protect the transformer completely from itself. If you'd spent 3 x the money you could have got around all this. A minor inconvenience considering the cost of the thing, just turn it off occasionally I think.
  9. gilford
    gilford
    Feb 12, 2005
    7,599
    +1,012
    Cheers MAW, you have kind of put my mind at ease :)
  10. jsgreen89
    jsgreen89
    Jul 23, 2004
    706
    +17
    Don't worry. It just means you have to turn it off for 15minutes every 2 hours. Just tell everyone it's like an old-time cinema intermission :D
