toshiba hack
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by gargoyle, Feb 21, 2001.
  1. gargoyle
    gargoyle
    Nov 8, 2000
    630
    birmingham
    +24
    Can any Toshiba SD100E owners confirm that a software hack has been found for this player?
    I was told previously that hardware upgrades were the only way to upgrade.
    Also , the source indicates that the hack allows the playing of RCE discs - I'd appreciate it if anyone could tell me what RCE discs are.
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    RCE: Region Code Enhancement
    The DVD will ask the player if it's a Region 1, Region 2 etc player.
    If the answer is YES more than once (as for all players with automatic codefree function, aka Code 0) it will refuse to play.
    In case of a manual region selection (usually via the remote control) the answer will be YES only once and it will play.
    There are - as usual - some exceptions to the rule, I have seen the Asian version of the Pioneer DV-636 playing RCE discs (ie The Patriot & Hollow Man, both R1) in automatic mode.
    Toshiba players can IMHO not be hacked by a code and need a hardware modification.
    But tell me if I am wrong, I am also looking for a new player and would be interested in a Tosh ....
    If I can't eat it, drink it or fudge it, I ain't interested.
  3. DaveH
    DaveH
    Aug 1, 2000
    743
    28
    Surbiton, Surrey
    +34
    I think Techtronics have a hardware mod for Tosh now.
    Otherwise you'll have to search when the disc is in stop mode and search on the TITLE that the film is located on.
    Not desireable as you lose the menus.
