Toshiba - Green Screen on HD ports only
Discussion in 'General TV Discussions Forum' started by PoorSap, Feb 10, 2009.
  1. PoorSap
    PoorSap
    Feb 10, 2009
    2
    Please forgive me if this has been covered in the forum already, but I ran a search after registering without any quality results.
    My Toshiba rear projection TV (about 4 years old) has developed a strong green tint but only on devices plugged into the HD ports. Everything is running normally and clarity isn't an issue. It's like the screen has a green film over it. Using the RCA jacks results in a normal (but non-HD) image.
    Warranty has expired. Any ideas where I should begin?
    Thanks.
  2. PoorSap
    PoorSap
    Feb 10, 2009
    2
    Okay, so I've discovered that I can get the TV to work correctly if I unplug it and plug it back in. But if I only turn it off and back on, the screen goes green. Unfortunately, sometimes I have to unplug it a few times for it to work. Any ideas?
