Toshiba ET1 - Cheap Replacement Bulb
Discussion in 'Projectors, Screens & Video Processors' started by Gordon WT, May 14, 2005.
  1. Gordon WT
    Gordon WT
    Dec 12, 2002
    151
    Inverness
    +8
    I bought one of these projectors a couple of weeks ago for about £365 and I have to say it is fantastic for the money. I got a 5ft pull-down screen from Ebay for less than £50 and attached it to my bedroom wall. With the projector sitting on a chair not that far way from the screen I get a tremendous picture for the money. :thumbsup: I'm using a Sony Dav-550 through component inputs and Progressive Scan.
    Anyway, I was looking for the cheapest place to buy a replacement bulb (hopefully the original will last close to it's stated 2000 hours - though I doubt it will!!) and found this site:
    http://www.tsi-europe.com/acatalog/TLPET1.html
    Can anybody beat that price?
    Gordon
  2. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,302
    Surrey. UK.
    +2,016
    That's a pretty good price for a lamp, even though it's almost half the cost of the pj it's for. Many are twice that price.
    This is more typical:
    http://www.bltdirect.co.uk/cat2004_1.htm
    I used Google and there are a few places selling lamps.
    Gary.
  3. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    I'd be careful of shelling out for a new bulb now unless you are a heavy user and are very likely to need a replacement while the unit is still under warranty.
    What if the unit requires a costly fix when just out of warranty? You may decide you've had your money's worth and buy a new PJ...PJ
  4. Gordon WT
    Gordon WT
    Dec 12, 2002
    151
    Inverness
    +8
    Very true.
    I was just checking out the best places to get a bulb for when the inevitable happens.
    To be honest if I get a year out of it at that price I'll be happy. You normally have to spend a grand to get a PJ that works as well as the Tosh. It's been a great introduction to PJ's for me as I had never seriously considered them for Home Cinema, thinking that a big plasma was the way to go......now I would consider a better model in the future with improved contrast.
    Gordon
