Viking61
There is now a way to make your HD-EP30 region free. :r0:
First of all I want to say that I don't take any credit in making the regionfree firmware. I only modified it to make it run on our players. It is a quite 'dirty method', so maybe it's not for all to do this. The procedure has to be followed very carefully, or you risk rendering your player useless.
The update procedure:
If you don't feel up to it, then it's better not to try. Hopefully there will come a better way to do it in the future. Having said that, the procedure have been tested on 4 players and all of those are now region free.
To make your EP30 or A30 (incl. PAL capability) region free:
1) EP30-dirty1
2) EP30-dirty2
3) Update your now region free player with the EP30 version 4.0.
To crossflash your EP30 or A30 (incl. PAL capability) into region free EP35-mode:
1) EP30-dirty1
2) EP35-dirty2
3) Update your now region free player with the EP35 version 4.0.
To make your A35 into PAL capable region free EP35:
1) EP35-dirty1
2) EP35-dirty2
To revert your EP30 or A30 from EP35-mode to EP30-mode:
1) EP35-dirty1
2) EP30-dirty2
3) Update your reverted player with the EP30 version 4.0.
If you decide to crossflash your EP30 or A30 into EP35-mode, you can see how bitstreaming will work in this post.
If you have an A30 or A35 and plan to make it into a regionfree EP30 or EP35, please ensure that your TV or projector can handle PAL before starting the process. Even though the EP30 and EP35 can playback NTSC, they will have PAL as default.
If you play a R1 DVD that is encoded with RCE, you will get an error message like: 'This disc is not formatted to play in this region'. You will then need to enter the RCE hack, which can be found here.
Disclaimer
By downloading the firmware files you agree that you fully understand the potential, like with any firmware update, to "brick" the player and are happy to attempt this firmware update at your own risk.
UPDATE !!!
My SkyDrive is now closed, so no need sending me PM for the "dirty firmware"
1. Insert the CD with firmware called EP30-dirty1
2. Answer Yes to update
3. The display will show VER UP for awhile, then count until STEP 2/4 before it stops with 10004050 showing on the display. The TV will still show “Updating. Do not turn off.”
4. Let it stay like that for 10 minutes
5. Unplug the power cord, wait 10 seconds and plug it in again
6. Turn the player on with the remote
7. There will not be anything shown on the TV
8. It will show WELCOME in the display for awhile, then it will show VER UP
9. Press Right Arrow (the button to the right of OK) once
10. Press OK once
11. The disc will eject
12. Insert the CD with firmware called EP30-dirty2
13. After awhile it will show VER UP in the display, then you press OK once
14. It will still show VER UP in the display for awhile, then it will count from STEP 1/4 until STEP 4/4
15. STEP 4/4 can take up to 20 minutes. Just wait and let it run its course.
16. The disc will eject and the player will turn itself off
17. Remove the disc and turn the player on with the remote
18. It will show WELCOME for awhile and then a small update will run, only STEP 1/1 and the player will turn itself off again.
19. Turn the player on with the remote and you have a regionfree EP30
You can now update to version 4.0 and still keep the regionfree setting.
1) EP30-dirty1
2) EP30-dirty2
1) EP30-dirty1
2) EP35-dirty2
1) EP35-dirty1
2) EP35-dirty2
1) EP35-dirty1
2) EP30-dirty2
Disclaimer
UPDATE !!!
