Toshiba Dvr-3
Discussion in 'TVs' started by moco, Dec 8, 2004.
  1. moco
    moco
    Does any one know the TOSHIBA DVR-3 DVD recorded and can say something for or against it?
  2. redaction
    redaction
    Nov 18, 2004
    111
    London
    Just sent back the Toshiba DR3 (no vcr) as it lacked component outputs. It was well built design though, and appeared to fix some of the faults of its predecessor, DR1, namely recording DVD-RW in VR mode and extending recording modes from just SP and LP (?) to XP, SP, LP and EP (with timer FR/variable bit rate recordings).
    Getting Panasonic DMRE55 multiregion as a replacement - has component and VBR recording can be done without having to set timer, loses support for DVD-RW though.
