toshiba dvr 16 wont format discs
Discussion in 'LCD & LED LCD TVs Forum' started by lastyboy, Jan 17, 2008.
Tags:
  1. lastyboy
    lastyboy
    Jan 17, 2008
    3
    3
    I have a Toshiba D-VR 16 dvd vhs combi. Just over a year old. It records fine but has stopped formatting blank DVD's. They load, then go to format screen which says 0% and flashes and then comes up with disc record error.
    I have tried with both Tesco and Sony DVD-RW's but to no avail. About 1 in 200 go's it will format.
    Any ideas.
  2. Jamesp1411
    Jamesp1411
    Hi, I have exactly the same problem and have tried different discs and keeps stopping at formatting stage with error message and code E4 54037380. Do Toshiba have a support site or a number to contact as cannot find one.:mad:
  3. laurieregan
    laurieregan
    Mar 9, 2008
    I also have same problem & have tried many disks & phoned Toshiba but to no avail. Has anyone found a solution to this problem?
  4. mrlolli
    mrlolli
    even though mine was a magnavox i was getting the same message and error code. after sifting through the net someone suggested running a dvd lens cleaner through it then blowing it out with compressed air. i tried it and it worked like a charm. hope it works for you.
  5. varkanoid
    varkanoid
    Jan 6, 2006
    635
    46
    +104
    can this be made region free ?
