Toshiba dvd recorder RD-XS 30
Discussion in 'Blu-ray & DVD Players & Recorders' started by alamo, Jun 16, 2003.
  1. alamo
    alamo
    Nov 25, 2002
    11
    Has anyone bought this new model yet ? What's your opinion of it compared to the Panny HDD model ?What does the "satellite monitor " control do ?
    Would it be better to wait until September when the new 80gb Panny comes out ?
    So many questions....but I want to make sure this is the model for me before splashing out on it.
    Thanks in advance...
  2. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,906
    71
    50 Rue St Georges, Paris.
    +32
    Hasn't component video outputs or DV input but looks interesting if these not needed.
  3. calibos
    calibos
    Aug 4, 2000
    931
    Ireland
    +33
    Read this thread Alamo
    Apparently it doesn't accept RGB input though it can output RGB. So no RGB loop through or RGB recording from most STB's. ie It can only record a composite or S-Video signal. I'll be waiting for the new Panny which fingers crossed will also do Pal Progressive.
  4. General Panic
    General Panic
    Jan 14, 2003
    721
    Scotland
    +18
    Hi alamo
    Regards waiting for the new Panny. My thoughts are at the mo the HS2 is about a £100 more than the Tosh so how much is the difference going to be in 4 months or so when the the 80gb version appears , a lot more me thinks.
    For the price difference the Tosh seems more appealing to me just now as RGB looping isn't a benefit i would use.
    Regards the techy questions , if you follow the link Calibos give , somewhere in that thread a kind hearted soul put another link to Toshiba's tech site where you can download the whole 160+ pages of the manuel. :)
    Let us know what you decide as i'm torn between the HS2 and the Tosh as well.
  5. leeb
    leeb
    Jan 10, 2003
    880
    28
    Melton Mowbray
    +52
    Well, after waiting for this machine for seemingly ages I've finally bit the bullet and have ordered the RD-XS30! :D It should arrive on Saturday so all being well I'll be able to report back here on my findings. The lack of rgb input didn't put me off too much as I haven't got $ky (and have no plans to) and my freeview box gives good results (for me) from its composite scart output. For £525 I think it should prove to be a very useful machine for timeshifting and watching programs when I want to rather than when the schedulers want me to!
    Lee
  6. General Panic
    General Panic
    Jan 14, 2003
    721
    Scotland
    +18
    Way to go leeb :) :)
    Be sure to get us updated on your thoughts when the machine arrives.
    If i might ask , where did you order it from? Was it Multizonedvd?
    I'm very keen on getting one as well and finding somewhere with stock's been a real challenge.
    All the best.
  7. leeb
    leeb
    Jan 10, 2003
    880
    28
    Melton Mowbray
    +52
    Yes, I ordered it from Multizonedvd. As well as proudly displaying they had stock they also did a Saturday delivery which is crucial for me. It's only region 2 but as I already have a multiregion player that didn't bother me.
  8. General Panic
    General Panic
    Jan 14, 2003
    721
    Scotland
    +18
    Cheers leeb
    That's the very place i will be ordering one from as well. The helpful staff member said the player is only region 2 but if a region hack was discovered or a download patch they would give that free of charge. If a mod was required if i pay return carriage they would mod for free!. A win win situation as long as you can do without multi-region to start with.
    I'll maybe hang fire till next week until i hear your words of wisdom regarding the machine though.
  9. Marcus Wood
    Marcus Wood
    Dec 28, 2002
    376
    London
    +4
    Is it definitely correct that there's no RGB input? If so, I find that a bizarre decision.
