Toshiba DVD Recorder Problems
Discussion in 'Blu-ray & DVD Players & Recorders' started by tommy100, Jan 12, 2012.
  1. tommy100
    tommy100
    Jan 12, 2012
    Hi There,
    Just bought a Toshiba DVR20KB. but having a problem.
    I cant seem to get the "General Settings" screen to come up on the screen.
    I CAN watch a DVD , I CAN watch a Video, so I feel that I am tuned in correctly as I am getting pictures comin from the DVD player to my television"
    But I cant get this "General Settings" up on the screen, which you need to do most of the important functions on this Recorder.
    The Instructions talk of a "stop mode", what is this.
    Any help would be greatly appreciated
  2. Broadz
    Broadz
    Oct 4, 2006
    8,697
    +1,423
    Stop mode means ensure that there is no disc playing (or recording) while you try to enter the Setup menu. The best bit is to eject any disc at all from the machine first.
  3. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,067
    +6,939
    It is possible that the TV is dropping the HDMI connection in certain modes, so if you want to be certain of seeing the output of the unit under all conditions, manually select the appropriate HDMI input on the TV using the TV's input selector.
