toshiba dvd player probs.
Discussion in 'Blu-ray & DVD Players & Recorders' started by bobbyrandall, Dec 18, 2004.
  1. bobbyrandall
    bobbyrandall
    hello all.probs with a toshiba sd900.on inserting some discs,say 1 in 6 of them the player stops or seems to get stuck almost straight away before you get to the menu or anything.the sceen is just blank . you can eject the disc and try again but you will get the same result.no button on the remote,ie play etc has any effect.the way around it i have come across is insert a disc that plays properly,let it run for a few seconds,eject it and put the problem dvd in.it then loads and plays properly!!
    bit of a pain really.any of you clever peeps got a solution???not impressed,this is an expensive player.
  2. gandley
    gandley
    Aug 31, 2003
    5,024
    Paradise Lost
    +269
    Is it MR enabled, and are the disc plying up region1 discs?
  3. bobbyrandall
    bobbyrandall
    hello ,i dont think it is mr enabled.i bought it in second hand.all the discs i play in it are region two,from the dvd shop,originals.i wont put pirate discs through it.any one got a clue?'
