Toshiba DVD -no audio
Discussion in 'Blu-ray & DVD Players & Recorders' started by Ivor_Monkey, Sep 25, 2005.
  1. Ivor_Monkey
    Ivor_Monkey
    Dec 12, 2002
    88
    I'm a bit stuck here. My daughter has a cheap DVD Toshiba SD 240E, which after one month seems to have decided not to output any audio via scart or phono plugs on a variety of systems. I hvae tried switching cables, TV, cd,dvds etc. Still no audio. The picture is fine.
    If this is a hardware problem, then it would make it the second faulty Tosh player we've had in about 4 months. Anyone come across this before? I guess it is possible for a DVD player to be faulty only on the sound.
    If it isn't a hardware problem, then I wonder if there is some hidden setting preventing audio output. As I say it used to work. I note that the online manual says that if DTS is chosen, then there will be no analogue sound. I haven't managed to find any option for changing DTS, so do not know how to find this. On the menu setting it offers only pcm or RAW.
    Any suggestions mightily appreciated?
  2. Ivor_Monkey
    Ivor_Monkey
    Dec 12, 2002
    88
    So, no one here knows.
    I have found the following possible explanation on the internet. Particular capacitators (or their soldering) may be causing the problem -makes sense, especially the intermitten nature of the problem. Replacing these and resoldering would be the way to go if the machine is out of warranty, but in my case, it is only a few months old and is going back. .
    http://forum.ecoustics.com/bbs/messages/2/1388.html
    I hope it helps somebody.
  3. Parklife
    Parklife
    Jun 9, 2004
    574
    28
    +33
    I had exactly the same problem on my 8 month old SD340. Suddenly stopped outputting any sound. I sent it back for a full refund.
  4. Ivor_Monkey
    Ivor_Monkey
    Dec 12, 2002
    88
    Parklife
    The supplier has agreed to fully refund.
    Incidentally, did you find a good replacement?
  5. Parklife
    Parklife
    Jun 9, 2004
    574
    28
    +33
    As it was still within a year I called Toshiba. They would have replaced it but did not have any in stock so they said to call the supplier. The supplier (Play) sent a courier to collect and gave a full refund. No hassles at all.
    As it was only used in the bedroom I have not got round to replacing it. Maybe the quality of the toshibas has dropped. I have another Toshiba which is 5 years old and is still as good as new!
