a little confused, i have been looking at the toshiba DR1 which seems to have the spec i want, however the DR3, which i assume is a newer model is cheaper in some retailers.
Is the DR1 a better machine with a different spec to the DR3?
also i need a component output and on some spec listings it says the DR1 has this and on others is says it doesn't whats the truth?
also is there a software/firmware upgrade to make the DR1 / DR3 play all regions not just region 2?
lots of questions
thanks
lots of questions
thanks
