Toshiba DR-1 playback problems
Discussion in 'Blu-ray & DVD Players & Recorders' started by DeeDub, Dec 27, 2004.
  1. DeeDub
    DeeDub
    I have recently got a Toshiba DR-1 DVD recorder but it doesn't seem to like playing some DVD's.
    It's a multi region model and so far I'm having problems playing "Meatloaf - live with the melborne symphony orchestra". This is a region 2,3,4,5,6 disc.
    It will not play "Lizzie McGuire" which is a region 2 disc. I get a message on screen saying "disc playback unauthorized"
    It will play other region 1 + 2 discs i have.
    Anyone have any ideas ?
    TIA for your support
    Deedub
  2. sdkmway
    sdkmway
    Dec 28, 2004
    112
    +4
    I had the same problem and narrowed it down to the machine throwing a wobbly after a recording had been made on a RW media. Some discs it liked some it didnt. Inserting a few discs eventually used to clear it. Enough was enough though and RS replaced it for a new one, so far I haven't had any problems, but this fault seemed to develop after a few months operation so we shall see.
    Kev
