Toshiba disappointing build quality.
Discussion in 'General TV Discussions Forum' started by Tel boy, Dec 2, 2004.
  1. Tel boy
    Tel boy
    Apr 2, 2001
    147
    UK-North East
    +5
    Just wondering does your Toshiba TV keep giving off loud cabinet cracks & creeks?
    I've had my 32” widescreen Tosh for about 9 months now & it has steadily got worse with the creeks & bangs. If its late at night & you are sitting watching something with the volume low it nearly scares the crap out of you when it does it :eek:
    On average it creaks or bangs about once an hour & sometimes it does a series of bangs.
    I can only put the creaking & banging down to poor build quality….I don't think it's a new issue as my old Toshiba TV done the same but I put this down to the TV being old etc.
    However here I am with a modern TV that is really starting to annoying me with the creaks & bangs :mad:
    Anyone else suffering the same?
    Tb.
  2. krusty
    krusty
    yep my toshiba 33 inch creaks and farts also..................................................but not as often as yours
  3. Kevo
    Kevo
    Aug 23, 2001
    5,397
    Manchester
    +149
    Yep, my 40" Tosh RO often creaks and makes some other strange noise like a deep thud every now and again!
    Mind you my old Sony WS Tv was a bit creaky too.
    I put it all down to age as my limbs are making similar noises when I bend them :rolleyes:
  4. DRGL
    DRGL
    Mar 30, 2004
    752
    Shropshire,UK
    One reason i don't like Toshiba-cheap cases,unlike this :-
    [​IMG]
    How a case should be :)
  5. vizslaraner
    vizslaraner
    Dec 13, 2003
    487
    Hereford
    Pity the TV's aren't up to much.
  6. sparkymarky
    sparkymarky
    Dec 12, 2002
    1,080
    48
    cornwall
    +32
    heard that it can be power supplies that give a small bang/creak/snap noise, nothing to worry about, allegedly, quite common iirc.
  7. Mango Bob
    Mango Bob
    Jan 12, 2004
    513
    16
    London
    Never heard a peep out of my 51wh36 rptv - the case and internals are silent. Can't fault the build quality either and it's sodding huge!
  8. DRGL
    DRGL
    Mar 30, 2004
    752
    Shropshire,UK
    Obviously haven't watched an HQ100 then...............
  9. Tel boy
    Tel boy
    Apr 2, 2001
    147
    UK-North East
    +5
    So it looks like I'm not the only one to notice the banging & cracking!
    Rather than mess around trying to enhance picture quality on the sets you would think the manufacturers would try to make a cabinet that doesn't spoil your viewing by banging & creaking a lot of the time. We never had this problem when TV's had the pressed hardboard type backs on them!
    If I had paid £200 for a low end TV I would maybe expect a few creaks from it ….but I don't think this is acceptable from an expensive TV.
    This is really starting to annoy me :mad: ….time to write to Toshiba I think!
    Tb.
  10. INchSHOrT
    INchSHOrT
    Sep 29, 2004
    115
    16
    I used to have a lot of creaks from an old Hitachi, but my new Toshiba 36zp48, no problems at all.
    Is your television near an entry/exit door,where it may rapidly heat or cool?
  11. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    Got 2 Toshibas and a Sony here....
    The Sony is about 12 yrs old now,and still works,putting up with No.3 child's abuse,and built like a tank.
    The 2 Tosh's are a 28" that has worked perfectly for 7 years,with one tube replacement thanks to the kids,and a 50"RPTV.
    Neither are as well built as the Sony,but both are perfectly solid(Esp the RPTV),and neither make any noises other than those they should make!
  12. Tel boy
    Tel boy
    Apr 2, 2001
    147
    UK-North East
    +5
    No it's not in any drafts or in a position where the temperature changes quickly.
    I guess it's just a crap TV :thumbsdow
    Tb.
  13. GaryB
    GaryB
    Nov 12, 2002
    5,387
    St Albans
    +1,294
    One thing that sometimes helps with expansion/contraction noises from plastic cases is to leave the set on for a few hours to get it hot and then loosen all of the rear cabinet screws by a couple of turns and then tighten them again. This re-seats the front and back cabinets in slightly different positions and can help.
