Toshiba differences
Discussion in 'LCD & LED LCD TVs' started by CHRISDOW, Apr 7, 2005.
  1. CHRISDOW
    CHRISDOW
    What is the difference between the 2 Toshiba models:
    26WL46
    27WL46
    Apart from the obvious 1 inch screen difference, are these the same sets, as I assumed I had ordered the 26, but my order says the 27
    I havent heard as good results regarding the 27 incher which is on its way.
    Not impresses with myself so far.
    The magazines rate the 26incher at 4 and 5 stars respectively, but no news or reviews regarding the 27inch.
    Chris
  2. kolabere
    kolabere
    Feb 8, 2005
    419
    +7
    Sorry can't answer your question fully, other than to say that Toshiba's website describes the 26 as "Retail Only", what ever that means. It sells for approximately £2-300 more than the 27.
    I have the 27 and have just started the battle to get a refund, because the DVI port doesn't work. Naturally, I would not recommend buying it.
  3. kolabere
    kolabere
    Feb 8, 2005
    419
    +7
    I may be wrong on this but I think that the 27WL46 is the replacement for the 26WL46.
    The rav reviews are in fact for the 26WL46B a different model all together.
    Clear as mud all this stuff ;) .
  4. CHRISDOW
    CHRISDOW
    Cheers all, i couldnt fathom it out myself,
    Nevermind
    Chris
