Toshiba confirms High Audio Bitstream support via firmware upgrade
Discussion in 'Blu-ray & DVD Players & Recorders' started by av addict, Sep 3, 2007.
  1. av addict
    av addict
    Jan 27, 2005
    2,218
    +179
    good stuff tosh:)
    Toshiba confirms High Audio Bitstream support via firmware upgrade What's New
    By Henning Molbaek
    FIRST PUBLISHED Sep 3, 2007
    This September will bring 1080 24p support to the Toshiba HD-A20 and HD-XA2 HD DVD player.
    At this years IFA (Consumer Electronics Show) in Berlin Toshiba confirms High Audio Bitstream support on second generation players via firmware upgrade. They hope to bring it to the HD-XA2 this October.
    This features allow for external decoding of HD audio codecs like Dolby TrueHD and DTS-HD.
  2. av addict
    av addict
    Jan 27, 2005
    2,218
    +179
    now for the question--will i be able to get dts-hd with my onkyo 674e amp
  3. Dave777
    Dave777
    Oct 25, 2002
    496
    Gatwick
    +22
    Can I assume this will mean that the EX1 (and E1) will get get it soon after?
    Dave
  4. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    Only the EX1 I think.
  5. harrytasker
    harrytasker
    Oct 7, 2006
    56
    no analog outputs on e1
  6. UrbanT
    UrbanT
    Jan 6, 2002
    13,312
    Aldershot, Hants
    +3,038
    Sending a bitstream output has nothing to do with the analogue outputs
  7. pioneerman
    pioneerman
    Mar 25, 2004
    2,596
    71
    surrey
    +74
    but does this mean the e1 will benefit through the optical or not?:confused:
  8. UrbanT
    UrbanT
    Jan 6, 2002
    13,312
    Aldershot, Hants
    +3,038
    No, the HD formats can only be output on bitstream via HDMI. But according to whats been posted the E1 won't get the update to allow this, so you have to assume its a limitation in the hardware of the bottom end machine.
  9. Rasczak
    Rasczak
    Apr 3, 2002
    22,790
    Warwick
    +3,419
    The E1 only has HDMI 1.1 doesn't it? If so that explains it as HDMI 1.3 or greater is required for bitstream transmission. The XE1 sports an HDMI 1.3 connection.
  10. StardustOne
    StardustOne
    Jan 8, 2006
    280
    28
    Switzerland
    +37
    The HD-E1 hast HDMI 1.2a.
  11. emthree
    emthree
    Jul 21, 2007
    2,233
    63
    +151
    My receiver (Yamaha 2600) has only the 1.1 HDMI. Although it is backward compatible with the higher profiles, I am not sure how it will transmit sound if I were to connect, say an E1, via HDMI? Will it be able to 'pass through' bit stream?
  12. UrbanT
    UrbanT
    Jan 6, 2002
    13,312
    Aldershot, Hants
    +3,038
    Its not a problem, the player will decode the sound and play it through the HDMI. The advantage of passing the bitstream is simply that you can choose whether the player or amp decodes the sound, depending on which you feel is better.
  13. TrevorS
    TrevorS
    Dec 2, 2005
    974
    43
    +175
    It applies to XA2 and XE1. It can only be done with HDMI 1.3, and so no other current players qualify.
  14. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +9,002
    Thanks for the post!
    Will the Xe1 be able to decode DTS-HD internally as well with this update?
    Or will we have to wait and see!
  15. Basil Plumley
    Basil Plumley
    Aug 10, 2000
    8,263
    Enjoying my system - for once!
    +723
    No you won't...the 674 dosen't have internal decoders for DTS HD master.
  16. kevny
    kevny
    Feb 19, 2006
    961
    Portsmouth
    +74
  17. forrestgump
    forrestgump
    Oct 31, 2000
    1,428
    huddersfield
    +49
    better late than never, I have my Onkyo 705 arriivng today so can't wait, I have not performed any firmware up-dates on my EX1 yet as I has not been plumbed in, after reading the booklet is it correct that you have to connect the lan cable to your broadband router then watch the on-screen display, so if the router is about 30 feet away from the plasma I need a 30m lan cable?
  18. UrbanT
    UrbanT
    Jan 6, 2002
    13,312
    Aldershot, Hants
    +3,038
    I'm in the same position, you would need a long cable. The alternative is simply to ring Toshiba and they will send the update disc to you. I've done this 2 or 3 times and its always arrived within a couple of days :)
  19. foxyloxy
    foxyloxy
    Jan 29, 2004
    152
    28
    +31
    Another idea re: cabling..
    If you have a wireless network at home but have a device which is not wireless (in my case a hd-dvd player but another example is the xbox360) then you either need to have cables trailing to wherever your broadband modem/router is located or buy a wireless bridge (these start at about £40 - the dedicated MS item for the 360 is more expensive). I came across another solution making use of a clearance item at maplin, code is A96FZ but doesn't appear on their website. The identical item is here for £20.15 (that's per socket - you need at least two) - the maplin kit includes two of these for £24.93 (bought in-store). It is only 14Mbps but suitable for most applications. Bargain!
  20. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    I use a wireless bridge connected to a small 5 port switch, it's a good solution if you have a few things to connect.
  21. foxyloxy
    foxyloxy
    Jan 29, 2004
    152
    28
    +31
    Or something like this:
    http://www.ebuyer.com/UK/product/97644
    (currently oos)
    which includes a switch.
  22. kevny
    kevny
    Feb 19, 2006
    961
    Portsmouth
    +74
    or you could just phone Toshiba on 01159766958 and they will send you a disc the very next day for nothing.
  23. DocDVD
    DocDVD
    Jun 26, 2006
    329
    28
    Bavaria
    +34
    Bitstream for the XE1 would be fantastic as I just finished setting up my new Denon 3808. :thumbsup:
  24. MI55ION
    MI55ION
    Nov 8, 2005
    5,853
    +690
    Are we ever likely to see an update for dts MA decoding inside the E1/XE1?
  25. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    My XE1 arrived yesterday, called Toshiba around midday and the disc arrived this morning....excellent service.
  26. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +9,002
    Been trying to find this out myself as well!
    I sent a PM to Robert from VE over on AVS (in the know with Xe1 updates) and he said.......no,might be considered in the future but sending it Bitstream is the way to go,apparently!
    Which supports my X-files theory,it's all a plot to force HDMI 1.3 receivers upon us.
    Cheers and have good Sunday,i know i will got pork.
  27. dav-t
    dav-t
    Nov 10, 2004
    5,248
    +580
    I read in HCC that the XE1 would only pass core dts MA they said it was a hardware limitation to do the decoding on board
    Regards
    Dave
  28. MI55ION
    MI55ION
    Nov 8, 2005
    5,853
    +690
    Kingfats,
    The point you make regarding HDMI 1.3 receivers is very plausible. I just think it's the new buzz word in the world of receivers, something to get everyone upgrading. Having looked into high bitrate DD and DTS in more depth following Smurfin's thread I just don't think DTS MA is enough to entice me to upgrade. I am perfectly happy with the sound I'm getting through my HDMI 1.2 receiver, I recently watched Renaissance which had a DTS MA track and the core track was more than sufficient to carry the movie. As I said a while back, DTS MA decoding would be a nice little bonus but nothing that anyone should lose any sleep over. :thumbsup:
  29. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +9,002
    Yep,this does seem to be the case!
    After some more reading it seems.....the Xe1 chipset limits the player to DTS MA being sent via Bitstream only and internal decoding would be impossible.
    Shame!
  30. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +9,002
    Hi MI55ION
    Good post and you're right it's not worth losing any sleep over!
    Perfectly happy with TrueHD and come on....how much better can DTS MA be!
    Lot of wasps about at the moment:)
