Quantcast
Toshiba BDX3200, regionfree DVD and multiregion BD
Viking61
Thanks to n3wk1d we can now welcome Toshiba BDX3200 in the family of fully regionfree Toshiba blu-ray players. You can make Toshiba BDX3200KB (British model) or BDX3200KE (European model) regionfree for DVD and multiregion for Blu-Ray by installing the regionfree firmware for the BDX3200KY (Australian model).
Download links for Toshiba BDX3200 regionfree firmware
The regionfree firmware can either be downloaded as an iso-file (BDX3200KY_RF.iso), and used with a program like ImgBurn (www.imgburn.com) to write the image file to a CD. Start ImgBurn and select 'Write imagefile to disc'. Put the CD in the player and the upgrade will start in a short time.
or
You can download the firmware file (BDX3200_APP.bin) itself and copy it to a USB-stick in a folder called UPG_ALL. Put the USB-stick in the player and go to Upgrade in the Setup Menu. Select upgrade from USB.
Edit 05.04.2014
New link to Toshiba firmware files:
https://onedrive.live.com/?cid=6948f2460bdd190c#cid=6948F2460BDD190C&id=6948F2460BDD190C!611
The only language in the firmware is english. If that is a problem for any non-english speakers, then you better not install it.
Procedure for changing regions (after installing the regionfree firmware)
1. Power on the blu-ray player.
2. Press "Setup" on the remote to enter Setup Menu.
3. Using the remote, enter "8520". A new submenu will appear.
4. Set DVD region code to "0" for DVD Multi Region.
5. Set BD region code as required using the remote buttons.
"1" = Region A, "2" = Region B, "4" = Region C
6. Press "Setup" button to exit the menu.
It would be nice if someone could try it, and report back how it goes. Also check which firmware version the player reports after installing it.
Viking61
269 views so far and no feedbacks ???
Didn't anyone try this regionfree firmware?
kris230980
I tried the USB method today and failed. However the 8520 submenu does work. Am not sure if it is a permanent method or temporary
Viking61
Did you make a folder called UPG_ALL and put the BDX3200_APP.bin file in there? Which error message did you get?
From Toshiba upgrade instructions:
Firmware upgrade requires USB Drive of max 2GB size. Please make sure to format the card with
FAT/FAT32 format before starting with the upgrade procedure.
kris230980
Hi Viking,
Thanks for the reply. I had the folder UPG_ALL and the card is also formatted in FAT 32. The system did take the upgrade and the message showed that the upgrade is complete and it took a reboot as well. However, the DVD region lock hasn't gone. I put in my fav "iRobot DVD" and it still says that its wrong region code. Then i went into 8520 submenu and reset the region for DVD's. Will this method also work for Blu-ray discs??
Viking61
Hi Viking,
Sounds like the procedure went as it should. :)
Go into the 8520 menu and set DVD region to 0 for regionfree DVD. In the same menu you set the blu-ray region of your choice. It will stay on this blu-ray region until you go the same place and change it.
kris230980
Hi Viking,
Thank you for the quick reply. I guess the BD code in the same menu refers to Blu-ray! Correct me if I am wrong. If that is the case, then I had already altered that as well for India (Region C). Thanks for all your help.
Regards
Gopi Krishna
Viking61
Yes, that's correct. BD code is the blu-ray code. 1 = region A, 2 = region B and 4 = region C according to the instructions.
Priority
Just done this, don't have anything region 1/A to test on it at the moment but seems to have worked so thanks very much OP!
Denner
Hi I can see that my 3200 is prompting mee to update to a new firmware,is it safe to do so and will it remain region free on both blu-ray and dvd ?
Viking61
Does it say which firmware version it wants to update to? The latest downloadable firmware on the Toshiba website is version 25, which is the same as the region free one. I suspect you might lose the region free if you upgrade. I wouldn't do it if you don't have any problems with the current firmware.
Denner
My bad, was not the Toshiba prompting me to update, it was my TV, all those gadgets wanting to update all the time, gets kind of confusing from time to time, sorry :)
nick.king
Works a treat many thanks, upgraded using a 4gb memory stick.
Just need a region free hack for my BDX1100 now :)
mocca
Thanks Viking61 for sharing this info, used and working :) i think as i have no other region disks.
andyj2
Just a quickie to say that Crampton & Moore are selling this player for £70, and Amazon for about £75......
Rather tempted, even though I won't be using the 3D just yet!
Useful info with regards the region-free mod!
Badagon
Thanx for great info, guys!
I'm goin buy Toshiba bluray player (British model) and i wanna to know, they support mkv files? toshibas australian site tells that they do, but no info on british site about it.
thanx.
Viking61
As your player essential will be an australian model after installing the regionfree firmware, I am pretty sure it will support mkv files if it says so on Toshiba's australian site.
jonib
For those having problems trying to update the firmware to region free, there is a guy selling region free CD's for all the Toshiba Blu ray players on ebay and he also includes instructions!
Badagon
after receiving my 3200, i installed regionfree firmware and it works very well. it plays mkv files too (i forgot check mkv before updating firmware, so i'm not shure about supporting mkv with original british firmware).
thanks, guys!
mckee74
Hello all. Thinking of picking one of these up and have a bit of a hypothetical question.
Won't lie, want to get as need a region free 3d player. If/when there have been firmware updates for the player, can you still upgrade the firmware and then reflash the player with the Australian firmware to make it region free?
(also just to check as I can't find a user thread for this player, it does bitsteam HD audio doesn't it?)
Thank you in advance to anyone reading this. Cheers.
rojgelf
I think tosh's do bitstream (don't own this one), but no you can't upgrade and reflash. Its the aussie f/w that is free, and its a certain f/w revision, but assuming tosh update that (and we can get it) then we should be ok for updates.
BTW what 3D films are locked that you want? Apart from locked US releases of gulliver (rubbish) and Rio (released in UK too), I think rest have been free.
mckee74
Thanks very much Roj. I'm presuming they must bitstream, the specs seem to suggest they do just not many reviews of this player out there.
Makes sense on the firmware. Seems the whole firmware thing is slowing down for a lot of players, thinks the kinks apart from the occasional disc have been ironed out so presuming safe to get the latest firmware and then put the region free on. Or at least I'll soon find out!
Regards 3D, yeah, maybe should have been more specific there. Not so much the 3D region locking that concerns me but just being able to have one player that does the lot so to speak. Have the Technika at the moment and it's a cracking piece of kit but just so darn ugly so seeing I can "upgrade" to region free, and 3D is a tad tempting.
rojgelf
1. My bdx1200 does so sure this will
2. Just put aussie f/w do not update it with UK first, aussie f/w will replace whatever you update.
3. True i have UK 3d panny and bdx1200 for other regions, so one player doing it all would be nice, (3200 was too expensive when i got 1200), and of course you will be ale to play region A 3D discs in the future.
mckee74
Superb. Cheers Roj.
jayfool
This works great, thanks!
I bought one of these players last week just to have a region free BD player, but mine tends to make a whining noise when the disc is spinning. Sometimes the whining noise seems louder than others, and it changes in tone when I switch chapters. Also, sometimes the player makes a really loud noise when I first insert a disc. Not quite grinding, but close, and only for a second. Is this normal with this player, or is mine defective? :confused:
Xeon99
Sounds defective, mine is quiet looks good and is more compatible than a noisy Sharp that got sent back under guarantee, happily the supplier exchanged it FOC.
This toshiba is all you need if your 3D tv already has smart functions which most of them do.
hdarpini
I have a question that's slightly off-topic but still related to making the Toshiba BDX3200 region-free/multi-region.
I'm on the verge of buying a BDX3200 in France but am confused by one of the specs listed on Toshiba's French website: "PAL Progressive Scan." What impact will this have on playing my American DVDs and BDs from Region 1/Region A? Will they still play, just without progressive scan?
I have been trying to research this but haven't found any definitive answers, so I'm hoping someone can clarify this point for me.
Thanks.
Latest News
Philips OLED burn-in solution is 95 percent effective
  • By Andy Bassett
  • Published
Philips TV’s with HDMI 2.1 and Dolby Vision IQ due in time
  • By Andy Bassett
  • Published
Sonos clarifies product update and recycling position
  • By Andy Bassett
  • Published
Philips 4th Gen P5 processor adds AI for more realistic images
  • By Andy Bassett
  • Published
LG regards HDR10+ as unnecessary
  • By Andy Bassett
  • Published
