Toshiba 900e owners...2 channel audio
Discussion in 'Blu-ray & DVD Players & Recorders' started by jonnyv, Apr 24, 2003.
  1. jonnyv
    jonnyv
    Mar 31, 2002
    2,145
    48
    +41
    Ive had my player for about a year now and listen to cd's via the analogue phonos, in the audio menu i have bitstream selected, ive just realised (correct me if im wrong) that because i have bitstream selected the dvd player has been outputting a bitstream signal down my phono leads to my amp for decoding ?
    Do i have to select analogue 2 channel in the audio menu to output an analogue signal via the phono out puts from the dvd ?
    Cant believe ive been doing this wrong for so long !!
  2. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,649
    UK
    +112
    jonny,
    bitstream only applies to the digital output, not the analogue ones - so you have been fine...
    generally use analogue phonos for music and digital coax or optical for DVD's
    JJ
  3. jonnyv
    jonnyv
    Mar 31, 2002
    2,145
    48
    +41
    Jasonjo, your probably right, ive re-read the manual and it appears that i dont have to select analogue 2 channel to use the phono leads.
