Toshiba 57" Vs Hitachi 55" ?
Discussion in 'General TV Discussions Forum' started by Lizzard, Apr 13, 2002.
  1. Lizzard
    Lizzard
    I am considering to buy one of these but i would like to know which one is the best.
    The Hitachi 55"
    Pros:
    Progressive Scan
    Cons:
    Weight
    The Toshiba 57"
    Pros:
    Weight
    Cons:
    No Progressive Scan
    What tubes does both of these RPTVs use?
    Does Hitachi got better electronics due to it can handle Progressive Scan which means it can take higher bandwith.
    Whats the reason Toshiba skipped Progressive Scan?
    Keep the costs down?
    Anyway, if anyone seen both side by side i would be happy if you could tell me which one you liked better.
  2. martian1
    martian1
    Dec 30, 2001
    2,466
    113
    Sunderland
    +679
    Well i own the 43"Hitachi and think it out performes the tosh and the progressive scan feature works well with R1 discs, i know of someone owning the 46" Tosh and the lines get on his wick!
    Other than that these sets are hard to pick fault with i would own either, the price you want to pay would probabaly clinch it thats why so many go for the Tosh.
    When i bought my set it was up against the older Tosh versions which i thought ugly and the build quality seemed pi.. poor. The new versions seem a lot better [looks wise].
    I must add though that the prog scan on my set is not true prog scan but it makes a much better picture than 100htz!
  3. Placebo2
    Placebo2
    Feb 15, 2002
    239
    London
    +5
    Hi Martin,
    Any joy with adjusting the convergance menu, within the service menu yet? Or any other picture adjustments.
    Cheers,
    John
  4. martian1
    martian1
    Dec 30, 2001
    2,466
    113
    Sunderland
    +679
    No i im quite happy overall although i wouldnt mind getting it calibrated!
