Toshiba 521 v Pioneer 565? And Progressive Scan!
Discussion in 'Blu-ray & DVD Players & Recorders' started by BAD Dave, Sep 17, 2003.
  1. BAD Dave
    BAD Dave
    Sep 16, 2003
    475
    Dundee
    +18
    I am about to upgrade my Toshiba 210 DVD player for either a Toshiba 530 or Pioneer 565. Both £200!
    Pioneer has upper hand on formats, being DVD-a & SACD (Toch DVD-A only) but Toshiba appears to have more comprehensive Progressive Scan capabilities (according to LEConcepts.com).
    1. What exactly does PS do?
    2. Will I need it with my regular widescreen TV or is it something reserved for plasma & rear projection TVs?
  2. JUS
    JUS
    Jan 21, 2003
    3,201
    Plute
    +243
    1. Have a look under the Progressive scan section of this forum.
    2. If your telly isn't progressive scan compatible and you don't plan on getting one then don't worry.
    SACD & DVD-A rocks....when you can find a disc you like.
  3. BAD Dave
    BAD Dave
    Sep 16, 2003
    475
    Dundee
    +18
    Ah, Yes. thanks.
    I hadn't even noticed that there was adedicated Progressive Scan forum!
