Toshiba 510E DVD-R problem solved!
Discussion in 'Blu-ray & DVD Players & Recorders' started by Jon Weaver, May 25, 2002.
  1. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,202
    Born in Bristol but now in Newport, (for my sins)
    +739
    Just thought you might like to know how to make DVD-R videos which work on the Toshiba 510E (And probably other Toshiba models)
    Simply use VOB's InstantCD+DVD version 6.4!
    In the past, I have tried PrimoDVD and Nero (5.5.8.2) and neither of these make disks which will play on the Toshiba.
    But, I just did a test using InstantCD and it worked first time.
    I hope this helps.
  2. encaser
    encaser
    Mar 15, 2001
    3,591
    Suffolk/Essex
    +1,206
    Interesting Jon, is the program copy right prohibitive? Nero isn't for cds, I just wonder if Instantcd+dvd is the same in that it warns you but lets you cpoy any way.
    Useful info though.
  3. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,202
    +739
    Its not 100% brilliant news...
    InstantCD/DVD 6.4 seems really unstable.
    I have a bunch of DVD filesystems on my Hard-disk. Verson 6.4 will write some of the, but do strange things to the others (i.e spit out the disk after writing exactly 1024Mbytes).
    I downgraded to 6.0, which seems a lot more stable, but it doesn't have "DVD Video" option.
    Instead I wrote a 'UDF Data' disk and this won't play on ANY player.
