Toshiba 510 : How to get best from it
Discussion in 'Blu-ray & DVD Players & Recorders' started by dUnKle, Aug 8, 2002.
  1. dUnKle
    dUnKle
    Jan 1, 2001
    13,378
    +1,325
    nice little player - have it connected via RGB until I can afford a projector and was just wandering how I can be sure im getting the best from it
    are there any simple tweaks that can be done ?
    is it worth using the dialouge boost on a 5.1 system ?
    and is there a way to find time remaining ?
  2. chic
    chic
    Jul 1, 2001
    5,975
    glasgow
    +871
    there is a way to find the time remaining on the disc to do this when plaing a disc press the button to switch on the virtual remote then move the curser up to the part of the display with the counter ticking away and it should chang to show you time remaining on the disc
