Toshiba 50XP27
Discussion in 'Plasma TVs Forum' started by sticker, Jan 15, 2003.
  1. sticker
    sticker
    Jan 14, 2003
    1,155
    36
    Sydney, Australia
    Anyone know anything about this model?
    How does it compare to the Pioneer PDP503HDE?
    Regards
    John
  2. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    I think it is a re-badged Panasonic 5 series, therefore it should be a good display and should out perform the 503HDE.
    Steve
  3. Member 14847
    Member 14847
    Aug 16, 2002
    491
    28
    +54
    The Toshiba 50WP27 is a rebadged Panasonic. You should note that the TU-PT600B tuner is not available for the Toshiba.
  4. sticker
    sticker
    Jan 14, 2003
    1,155
    36
    Sydney, Australia
    Thanks for your help guy's, but is there an alternative tuner available for this?
    John
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,496
    The Borders
    +3,464
    John
    Why the requirement to have a tuner?
    If its switching there are better ways of doing it.
    If its for Teletext then you can add in a £140 external box to any Plasma Display that will give you Teletext and also give your Composite and S-video signals a bit of a clean up in the process.
    If your after the convenience of the PlasmaTV (including the external Switcher/Tuner) rather than the Plasma Display (No Tuner or SCART inputs) and dont want to use external switching and conversion with one of the Display models then I would stick with the Pioneer PDP-503HDE; we have many customers using these and the smaller 43" model and no major complaints.
    Best regards
    Joe
  6. sticker
    sticker
    Jan 14, 2003
    1,155
    36
    Sydney, Australia
    Hi Joe,
    Thanks for your advice.
    The reason I was after a tuner was twofold, one I'm a plasma "virgin" so I'm not really sure what I need and the second is that I want to retain the benefits and functionality of my current CRT TV.
    Basially I want to retain connectivity (including component and SCART), teletext and PIP. I'm not certain if the first point can be overcome when I upgrade my Amp and use that as a switch box. As an additional constraint I will be moving to Australia in the next 5 to 6 months so want to make sure anything I get will work there.
    Can I use my current Sky box to receive signals?
    And finally would this mean that the MXE version of this monitor is a better option or is it an inferior model.
    Many thanks for you help
    Regards
    John
