toshiba 50wt29b (HELP!)
Discussion in 'TVs' started by mickyiz29, Oct 7, 2003.
  1. mickyiz29
    mickyiz29
    Hi people just a bit of advice please.
    I was doing the service level convergence on my set and when i went into it i pressed 5 instead of 7 ooops! the picture went really funny when i reset the tv it was fine. What is this??
  2. mickyiz29
    mickyiz29
    anyone??
  3. mickyiz29
    mickyiz29
    does anyone know the default settings for the Tosh 50wt29B ?
    Thanks in advance.
  4. Realdeal.UK
    Realdeal.UK
    I have the 42" version, i believe there is no default settingd. Just make sure you note down all the origional settings before you try to change. I didn't and suffered. Fortunately I had a major bleed problem and got the set replaced. Running a treat now.
  5. mickyiz29
    mickyiz29
    yeah as i was going into the convergence menu when the remote got knocked i don't know what got changed the picture now looks grainy like the contrast is high or something? any ideas?
  6. mickyiz29
    mickyiz29
    think i've sorted it seemed to be the brightness does anyone know what code adjusts the contrast in the service menu?
  7. nathan_silly
    nathan_silly
  8. mickyiz29
    mickyiz29
    thanks for that nathan as i say it seems pretty much back to how it was now. nut sure if i knocked the brightness down in manual picture mode then turned it up on picture mode 1 messing the the default settings have adjusted it back and it does seem okay have not been in designer mode so i could'nt have changed any of those parameters, could I ?? think i'll stop tweaking for a while now have written down all my defaults now anyway in case i am tempted.
    just looking at it now and if anything the pic seems better;)
    strange?!
