Toshiba 50WT29 Problem
Discussion in 'General TV Discussions Forum' started by john_1958, Jul 26, 2005.
  1. john_1958
    john_1958
    My 50WT29 has a problem whereby it has an intermittent fault. This fault, when happening, manifests as no picture or sound but you can access the menu, after a delayed period, and that appears as 3 badly mis-converged and curved menus.
    If the set is turned off and on again it sometimes recovers and shows a picture and sound just fine. Then, sometimes, when a channel is changed or the AV source is changed, it just stays on the previous source.
    Now I am told that this is software/data fault whereby the processor is not reading the data table due to a faulty "something". And its this "something" that I need to indentify.
    Can anyone help please ?
    Someone has said that it might be the EPG module but I dont know where this is situated. Can anyone point me in the right direction ?
    Thanks in advance.
  2. rockminster
    rockminster
    Did you ever manage to get this issue resolved, I am suffering from the same problem with my 50wt29 at the moment.
