Hi new user so be gentle
I have just purchased the above equipment and want to check that I have it connected for best sound available to me
The set up is currently
PS3 Soundbar HDMI1
Sky+ Box Sounbar HDMI2
Soundbar HDMI out TV HDMI1 (ARC compatible if I read the specs correctly)
I select either PS or Sky by using the soundbar remote HDMI1 or 2 as appropriate
Is this the best way to do it or should I be connecting PS3 and SKY to TV and then HDMI or optical from TV to soundbar?
Based on above setup or indeed any other suggestions a bit of advice on PS3 Audio settings would be appreciated as well it works at moment and sounds OK but conscious I may not be fully utilising
Many Thanks
Doug
PS3 Soundbar HDMI1
Many Thanks
Doug
